11-07-2012 10:57 PM - edited 03-07-2019 09:55 AM
I am having some difficulty setting up a lab utizling a layer 3 switch as an intrem solution to a network problem i am having.
What I would like to do is move the ISP (100.10.10.*) endpoint ip address, to a routed port on the WAN Switch C3750G, then I want to leave the current ip addresses 200.20.20.0 on the router and ASA, and have them route their traffic to the routed interface on the switch - then out to the ISP etc
L3 Switch:
hostname Switch
ip routing
spanning-tree mode pvst
interface FastEthernet0/1
switchport access vlan 200
switchport mode trunk
interface FastEthernet0/2
interface FastEthernet0/3
no switchport
ip address 100.10.10.1 255.255.255.252
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
interface Vlan200
ip address 200.20.20.1 255.255.255.252
router eigrp 100
network 200.20.20.0 0.0.0.15
network 100.20.20.0 0.0.0.3
auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 100.10.10.2
Router:
interface FastEthernet0/0.200
encapsulation dot1Q 200
ip address 200.20.20.2 255.255.255.240
Solved! Go to Solution.
11-08-2012 05:47 PM
Okay. You'll need to nat on your switch. It's going to depend on what type of switch you have if you're even able to do it....
The problem is that your 100.10.10.2 device doesn't know how to get back to the 200.20.20.0 subnets, so the traffic is dropping.
*** Edit ***
I saw that you have a 3750 switch, and according to the below link, NAT isn't supported:
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a008011c629.shtml
11-08-2012 04:22 AM
The first thing that I notice, and probably doesn't have anything to do with the problem, is that the mask doesn't match between vlan 2 and the router's subinterface. What is the actual problem though?
11-08-2012 04:48 AM
Yes realised that was wrong mistake when chaning details.
I am finding that i am unable to route between the 200.x.x.x network and the 100.0.0.0 network. i can ping the routed interface on the switch but traffic will not pass beyond it.
11-08-2012 06:21 AM
Can you post the following?
From the switch:
sh ip route
ping 100.10.10.2
ping 200.20.20.2
ping 200.20.20.3
From the 2811:
sh ip route
ping 200.20.20.1
ping 100.10.10.1
ping 100.10.10.2
From the ASA:
sh route
ping ISP 100.10.10.1
ping ISP 100.10.10.2
ping isp 200.20.20.1
HTH,
John
11-08-2012 07:07 AM
are both your 2811 and ASA having a default route configured pointing to 200.20.20.1?
And the ISP a static route for 200.20.20.0/28 pointing to 100.10.10.1?
HTH,
Milan
11-08-2012 04:45 PM
switch:
Show ip route:
100.0.0.0/30 is subnetted, 1 subnets
C 100.10.10.0 is directly connected, FastEthernet0/3
200.20.20.0/30 is subnetted, 1 subnets
C 200.20.20.0 is directly connected, Vlan200
S* 0.0.0.0/0 [1/0] via 100.10.10.2
Ping:
can pin 200.20.20.1
can ping 200.20.20.3
can ping 100.10.10.1
can ping 100.10.10.2
router:
can not ping 100.10.10.1
can ping 200.20.20.1
ASA:
cannot ping 100.10.10.1
can ping 200.20.20.2
11-08-2012 04:58 PM
Does your router know how to get to the 100.10.10.0 subnet? Can you post the routing table from the router and the ASA? Also, from the switch, can you post "sho ip eigrp neigh"?
11-08-2012 05:22 PM
In this instance i have not allowed routing protocols to exchange between the switch router and ASA,
i have place a static route on both devices pointing toward in intervlan interface of 200.20.20.2 i can now ping the 100.10.10.1 interface but not the 100.10.10.2 interface.
11-08-2012 05:47 PM
*** Edit ***
11-08-2012 06:22 PM
Thankyou for your assitance, i will keep working at it until i figure something out.
11-08-2012 06:35 PM
What's the driving decision to connect your ISP directly to the switch? What connects to the other side of the ASA and the routers? Is there a way to rearrange this where your router connects to the ISP instead and then you can configure natting easily enough. If you're not natting on the router now, you could connect the 200.20.20.0 subnet as a routed port and replace the router with the switch, and then put your 100.10.10.1 address on the router and then configure nat. I'm not sure if that would work for you:
Something like:
ISP
| 100.10.10.0
Router
| 200.20.20.0
Switch--------------ASA
200.20.20.0
HTH,
John
11-08-2012 06:44 PM
i am using it as temporary solution while migrating over to new equipment , current equipment is being replaced and awaiting for new equipment to arrive needed a solution that would fill in as a WAN switch until such time
11-08-2012 07:53 PM
Do you have another router that you can throw in between the switch and the ISP? If so, that would be your best bet. You could create a /30 between the switch's routed port and the router, and then configure nat there and have your 100.10.10.1 address on the wan side of the router.
John
11-08-2012 08:34 PM
Unfortunatley that is what i am wating on.
