CDP nei question between 2 cisco devices
mahesh18
Level 6
Level 6
                   Hi all,
We have cisco router and switch which have direct connection between them.
From Router int say gi0/1 goes to non cisco device.
Switch interface say gi0/2 also goes to same non cisco device.
When i do sh cdp nei on switch  int  gi0/2   it shows Router as nei.
Need to know why it is like this?
Mahesh
2 Accepted Solutions
John Blakley
Mahesh,
CDP is a l2 protocol, so if you have a Cisco router connected to a non-Cisco switch, and another Cisco switch connected to that one, the router will see the Cisco switch on the other side of the non-Cisco switch. The Cisco switch will see the router as a neighbor because the non-Cisco switch is still allowing the CDP traffic to pass.
HTH,
John
HTH, John *** Please rate all useful posts ***
The Cisco devices will see each other as neighbors as long as CDP is running on those interfaces. CDP packets will pass through the non-Cisco switch unhindered. The downside is you don't know what device is between the 2 Cisco devices because they look like they're directly connected when in fact they're not.
You should still be able to see a device if it's connected to a routed port on a switch. Usually, you want to disable running cdp on an interface that leads to a service provider for security reasons.
HTH,
John
John Blakley
Mahesh,
HTH,
John
Hi John,
So does it mean that both cisco devices will see each other as nei?
Also what if we have layer 3 interface does will it make difference?
Mahesh
HTH,
John
Hi John,
Many thanks again
MAhesh
