L3 Switch(with Intervlan) connecting to Router
ITexpert
Level 3
Level 3
Hello Guys,
I configure Aruba 2930F with Intervlan routing and configure ip routing, setup static route :
ip routing
vlan 1 :  ip address 10.10.31.65   255.255.255.0
vlan 50: ip address 10.110.50.1 255.255.255.0
Vlan 51 : ip address 10.110.51.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.10.1.1 (router interface)
then on router i configure one  port with IP 10.10.1.1 255.255.255.0 , no shutdown.
Then i configure static routes on router, ip route 10.110.50.0 255.255.255.0 10.10.31.65
        ip route 10.110.51.0 255.255.255.0 10.10.31.65
I can not ping Router ip from switch and switch from router. ?
I am confuse the port that connected from switch to router should be trunk configured or access ?
rais
Level 7
Level 7
Your route on Aruba:
is invalid as there is no presence of 10.10.1.x network on Aruba. Aruba can't reach 10.10.1.1 so it can't use this static route.
HTH.
Hello rais,
I change my router address to 10.10.31.75 and 10.10.31.0 is the default vlan on Aruba switch, Now i can ping my router from Aruba and vice-versa.
But when on access layer switch, I connect PC, It cannot ping router ?
I already have static route-  ip route 0.0.0.0 0.0.0.0 10.10.31.75
Do you have a vlan1 interface on switch with address 10.10.31.x?
Thanks.
