L3 to L2 not working in CML
cwkronk1982
I have a layer 3 port with an IP of 192.168.1.1/24 on a iosv l2 image connected to a layer 2 port on a osv l2 image. The layer 2 port is access and allowing vlan 10. There is an SVI with vlan 10 with an IP of 192.168.1.10. I can't get the two IPs to ping. On the switch with the L3 port, the mac address table is completely blank. If I change the port to L2, the mac address populates with the MAC of the connected port on the L2 switch. As soon as I change it back to L3, it goes blank again. This should work. I've seen this work many time in live environments. Is this just not supported in CML?
5 Replies 5
Harold Ritter
Hi @cwkronk1982 ,
What is the IOS L2 version that you are running? Can you provide a "show ip int brief" from the 2 devices.
Experimental Version 15.2(20200924:215240) [sweickge-sep24-2020-l2iol-release 135]
south(config-if)#do sh ip int br
GigabitEthernet0/0 unassigned YES manual up up
GigabitEthernet0/1 unassigned YES manual up up
GigabitEthernet0/2 unassigned YES unset up up
GigabitEthernet0/3 unassigned YES unset up up
Port-channel10 192.168.1.1 YES NVRAM up up
south(config-if)#do sh run int po10
Building configuration...
Current configuration : 85 bytes
interface Port-channel10
no switchport
end
west(config-if)#do sh ip int br
GigabitEthernet0/0 unassigned YES unset up up
GigabitEthernet0/1 unassigned YES unset up up
Port-channel10 unassigned YES unset up up
Vlan10 192.168.1.20 YES manual up up
west(config-if)#do sh run int po10
Current configuration : 83 bytes
switchport access vlan 10
switchport mode access
end
Thanks @cwkronk1982 . Can you provide a "show run int" for the port(s) that are part of the port-channel on both switches.
west(config-if)#do sh run int g0/0
Current configuration : 131 bytes
interface GigabitEthernet0/0
negotiation auto
channel-group 10 mode on
end
west(config-if)#do sh mac add
Mac Address Table
Vlan Mac Address Type Ports
10 5254.0005.bbf7 DYNAMIC Po10
10 5254.000e.b947 DYNAMIC Gi0/2
Total Mac Addresses for this criterion: 2
west(config-if)#do sh etherc sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
10 Po10(SU) - Gi0/0(P)
south(config-if)# do sh run int g0/0
Current configuration : 110 bytes
no switchport
no ip address
negotiation auto
end
south(config-if)# do sh run int g0/1
interface GigabitEthernet0/1
no switchport
no ip address
negotiation auto
end
south(config-if)#do sh mac add
Mac Address Table
south(config-if)#do sh int po10
Port-channel10 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 5254.0005.8000 (bia 5254.0005.8000)
Internet address is 192.168.1.1/24
MTU 1500 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
Keepalive set (10 sec)
Last input 00:00:01, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
62771 packets input, 3951585 bytes, 0 no buffer
Received 0 broadcasts (0 IP multicasts)
14070 packets output, 1524749 bytes, 0 underruns
0 unknown protocol drops
0 lost carrier, 0 no carrier
south(config-if)#do sh etherc sum
d - default port
10 Po10(RU) LACP Gi0/0(P) Gi0/1(s)
east(config-if)#do sh run int g0/1
Current configuration : 80 bytes
negotiation auto
end
east(config-if)#do sh etherc sum
d - default port
10 Po10(SN) LACP Gi0/1(w)
 is @cwkronk1982 ,
I am not sure what your topology is. You mentioned 2 switches, but I now see 3 (south, west and east). Can you provide a simple diagram.
BTW, I ran a quick test with two switches in CML as you originally described and it works for me. Let me know if you would like me to provide the yaml file. Here's the configuration summary:
L3-Switch:
no switchport
no ip address
no switchport
L2-Switch:
interface Vlan10
ip address 192.168.1.20 255.255.255.0
