Lab setup Sub Vlan Routing Help.
kb1ojr001
I will do my best to explain this. As I am really just starting to dive into my CCNA studies.
I have a cisco 3550 24port switch connected to a 2801 router, which is connected to my pfsense box handing the cisco 2801 router a DHCP ip address. I have a static route on my pfsense box to get me access to the cisco ip ranges I add to the inside IP address for example.
on the router I have the following.
PfSense gateway is 10.1.200.254 and is going to cisco router on fa0/0 is ip 10.1.200.1 255.255.255.0
cisco router fa0/1 is 172.24.1.254 which is going to my cisco 3550 switch on fa0/1 172.24.1.1
On the switch I have vlan 1 setup as 172.24.1.1 and from any ip address added to that range on any port I can ping to my gateway and the internet (e.g 8.8.8.8 and cisco.com for example)
When I create a sub interface I can ping as far as my pfsense box which is at 10.1.200.254
From the cisco router I can ping dns names and direct IP with no problems, it is from the switch I am having difficulty pinging from.
Below is my router and switch configs.
Please note the following port descriptions.
Port 1 on the switch is the trunk to the cisco 2801 router
port 13 is to a local physical PC
port 24 is a trunk to a Esxi server running in particular vlan 200 and 201 for my cisco lab.
Any help would be appreciated. As I have hit a virtual wall :) Thank you kindly in advance.
####Router Configuration
Current configuration : 1593 bytes
version 12.4
service config
hostname R1-2801
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip domain lookup
no ip ips deny-action ips-interface
R1-2801#conf t
Enter configuration commands, one per line. End with CNTL/Z.
R1-2801(config)#ip dom
R1-2801(config)#ip domain l
R1-2801(config)#ip domain loo
R1-2801(config)#ip domain lookup
R1-2801(config)#do show run
Building configuration...
Current configuration : 1573 bytes
version 12.4
service config
hostname R1-2801
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
interface FastEthernet0/0
ip address dhcp
ip nat outside
no ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.24.1.254 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1.200
encapsulation dot1Q 200
ip address 172.200.1.254 255.255.255.0
ip nat inside
no snmp trap link-status
interface FastEthernet0/1.201
encapsulation dot1Q 201
ip address 172.201.1.254 255.255.255.0
interface Serial0/3/0
no ip address
shutdown
router rip
version 2
network 10.0.0.0
network 172.24.0.0
network 172.200.0.0
network 172.201.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.1.200.254
ip http server
no ip http secure-server
ip nat inside source list NAT_ADDRESSES interface FastEthernet0/0 overload
ip access-list standard NAT_ADDRESSES
permit 172.201.1.0 0.0.0.255
permit 172.200.1.0 0.0.0.255
control-plane
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
logging synchronous
login
end
R1-2801(config)#
#########################SWITCH Configuration#################################################################
SW1-3550-24poe#show run
Current configuration : 2436 bytes
version 12.2
no service pad
hostname SW1-3550-24poe
no aaa new-model
ip subnet-zero
spanning-tree mode pvst
spanning-tree etherchannel guard misconfig
vlan internal allocation policy ascending
switchport mode trunk
switchport nonegotiate
interface FastEthernet0/2
switchport mode dynamic desirable
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
switchport access vlan 201
switchport mode access
spanning-tree portfast
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface Vlan1
ip address 172.24.1.1 255.255.255.0
interface Vlan201
ip address 172.201.1.1 255.255.255.0
ip classless
ip http server
control-plane
line con 0
password cisco
logging synchronous
login
line vty 0 4
password cisco
logging synchronous
login
line vty 5 15
login
end
SW1-3550-24poe#
kb1ojr001
Also forgot to add, I setup rip v2 on the router and my pfsense has an addon for it, seems to be working as far as I can tell. Also added domain lookup on the switch to be able to ping easier.
Below is some pings from the switch and a "show ip route" of the router
Success rate is 0 percent (0/5)
SW1-3550-24poe#ping 172.24.1.1
Sending 5, 100-byte ICMP Echos to 172.24.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
SW1-3550-24poe#ping 172.24.1.254
Sending 5, 100-byte ICMP Echos to 172.24.1.254, timeout is 2 seconds:
SW1-3550-24poe#ping 172.201.1.254
Sending 5, 100-byte ICMP Echos to 172.201.1.254, timeout is 2 seconds:
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 28/32/40 ms
SW1-3550-24poe#ping google.com
Translating "google.com"...domain server (10.1.1.1) [OK]
Sending 5, 100-byte ICMP Echos to 172.217.10.46, timeout is 2 seconds:
SW1-3550-24poe#ping cisco.com
Sending 5, 100-byte ICMP Echos to 72.163.4.161, timeout is 2 seconds:
SW1-3550-24poe#
And here are some DNS pings from the router which are successful.
R1-2801#ping google.com
Success rate is 100 percent (5/5), round-trip min/avg/max = 24/31/36 ms
R1-2801#ping cisco.com
Success rate is 100 percent (5/5), round-trip min/avg/max = 64/76/80 ms
R1-2801#
R1-2801#show ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is 10.1.200.254 to network 0.0.0.0
172.200.0.0/24 is subnetted, 1 subnets
C 172.200.1.0 is directly connected, FastEthernet0/1.200
172.201.0.0/24 is subnetted, 1 subnets
C 172.201.1.0 is directly connected, FastEthernet0/1.201
172.20.0.0/32 is subnetted, 2 subnets
R 172.20.1.1 [120/1] via 10.1.200.254, 00:00:21, FastEthernet0/0
R 172.20.1.2 [120/1] via 10.1.200.254, 00:00:21, FastEthernet0/0
172.24.0.0/24 is subnetted, 1 subnets
C 172.24.1.0 is directly connected, FastEthernet0/1
10.0.0.0/8 is variably subnetted, 7 subnets, 2 masks
R 10.1.3.0/24 [120/1] via 10.1.200.254, 00:00:21, FastEthernet0/0
R 10.0.2.1/32 [120/1] via 10.1.200.254, 00:00:21, FastEthernet0/0
R 10.1.1.0/24 [120/1] via 10.1.200.254, 00:00:21, FastEthernet0/0
R 10.0.2.2/32 [120/1] via 10.1.200.254, 00:00:23, FastEthernet0/0
R 10.1.4.0/24 [120/1] via 10.1.200.254, 00:00:23, FastEthernet0/0
R 10.1.30.0/24 [120/1] via 10.1.200.254, 00:00:23, FastEthernet0/0
C 10.1.200.0/24 is directly connected, FastEthernet0/0
R 192.168.0.0/24 [120/1] via 10.1.200.254, 00:00:23, FastEthernet0/0
S* 0.0.0.0/0 [1/0] via 10.1.200.254
R1-2801#
R1-2801#
R1-2801#
Try adding a default gateway to the switch:
ip default-gateway 172.24.1.254
Just to clean things up a bit, you could re-arrange the 2801 config to the switch to look like this:
interface FastEthernet0/1.1
encapsulation dot1Q 1 native
ip nat inside
ip nat inside
ip nat inside (I assume you also want to NAT this)
This way you are not using the major interface in addition to sub-interfaces. Like i said, it is just cleaner. May or may not make a huge difference.
