Join Customer Connection to register!
200
groupedlsi
Beginner
LACP across two 2960s
Hello, does anybody know if I can setup a cross-stack LACP between two stacked C2960S-48TS-L(with the additional stack module) ?
If it is, is there any limit (ports or groups limits)?
Thanks a lot,
Ludovic
2 ACCEPTED SOLUTIONS
glen.grant
Advisor
  You should be able to do that .  On older 2960's they were limited  to  6 port channels per box , don't know if that has changed on the newer 2960's or not.
Ankur Arora
Beginner
Cross Stack LACP is possible.
However you still have there is a limitation to 6 port-channels.
Please go through the following link for details:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swethchl.html#wp1275881
Ankur
"Please rate if found useful"
2 REPLIES 2
glen.grant
Advisor
Ankur Arora
Beginner
Ankur
