LACP between 3750 and Enterasys C2
John_Lenehan
Hello, has anyone successfully
usedlacp to connect to an Enterasys C2 (or A2 for that matter) switch? The connection works from the 3650 to a 3550. The Enterasys lag works from the C2 to an A2 but when I try to connect the 3750 to the C2 the port-channel won't come up.
core#sh ether 1 detail
Group state = L2
Ports: 2   Maxports = 16
Port-channels: 1 Max Port-channels = 16
Protocol:   LACP
                Ports in the group:
Port: Gi1/0/47
Port state    = Up Sngl-port-Bndl Mstr Not-in-Bndl
Channel group = 1           Mode = Active          Gcchange = -
Port-channel  = null        GC   =   -             Pseudo port-channel = Po1
Port index    = 0           Load = 0x00            Protocol =   LACP
Flags:  S - Device is sending Slow LACPDUs   F - Device is sending fast LACPDUs.
        A - Device is in active mode.        P - Device is in passive mode.
Local information:
                            LACP port     Admin     Oper    Port        Port
Port      Flags   State     Priority      Key       Key     Number      State
Gi1/0/47  SA      indep     32768         0x1       0x1     0x2F        0x7D
Age of the port in the current state: 0d:00h:01m:19s
Port: Gi1/0/48
Local information:
Gi1/0/48  SA      indep     32768         0x1       0x1     0x30        0x7D
Age of the port in the current state: 0d:00h:01m:15s
                Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:01h:16m:00s
Logical slot/port   = 10/1          Number of ports = 0
HotStandBy port = null
Port state          = Port-channel Ag-Not-Inuse
Protocol            =   LACP
Time since last port bundled:    0d:00h:09m:18s    Gi1/0/47
Time since last port Un-bundled: 0d:00h:06m:46s    Gi1/0/47
core#
Any ideas?
John_Lenehan
Just an update if someone else is stuck, I changed the C2 to remove any
reference to static ports and the link comes up. Don't know why. Hopefully someone at Enterasys can provide an idea..
Thanks to those that looked.
John
