LACP configuration sample on Cisco 3750-12S
chris.lau
I have 4 units of Cisco 3750, 12 ports stacked switches.
I have port channel configured on the stacked switches.
SW1, Stacked 1 G1/0/1 connected to G1/0/1, SW2, Stacked 1
SW1, Stacked 1 G2/0/1 connected to G2/0/1, SW2, Stacked 1
Then, I will configure a port channel, say Po1
I knew that for x-stack etherchannel, I need to use LACP instead of PAGP.
How do I make sure that the LACP protocol was used?
Does it means that if I used " channel-group 1 mode active" command, then, the cisco 3750 will automatically using LACP?
Or, do I need to use the "channel-protocol lacp" command?
mahmoodmkl
Level 7
Level 7
If u used the channel-group 1 mode active LACP will be automatically enabled for the channel.
Mahmood
mahmoodmkl
Level 7
Level 7
Mahmood
Hi Chris,
This link will provide you all options....
http://www.cisco.com/en/US/products/hw/switches/ps5023/products_configuration_example09186a00806cb982.shtml
Hope This Helps....
Shaheen
