LACP interface priority - default value
Marcogiraldo86
Frequent Visitor
Frequent Visitor
Hi guys
I am studying CCNP-ENCOR book.
I have a doubt, which is the priority default value of interface partecipate to LACP?
In book example, it set G1/0/2 with command "lacp port-priority 1" and G1/0/2 become active
If i look for documentation, default value should be 1 and range should be (1 to 65535)
In my opinion it should change G1/0/1 port priority higher value than 1 to become G1/0/2 active, isn't it?
5 Replies 5
aleabrahao
Meraki Community All-Star
The default value is 32768 and Lower value = higher priority.
But to be quite honest, in practice I've never seen anyone change the default priority.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
From cisco documentation, default value is 1
I know that anyone change default priority, it's to find correct info.
Hello @Marcogiraldo86
From my C9500 agg switch.
Also cisco guide
Default EtherChannel Configuration
aleabrahao
No, the documentation shows how to set the priority, the default value is 32768.
Hello @Marcogiraldo86 ,
other colleagues are right the default value should be 32768.
The lowest priority is preferred.
The use case is when you have one member link that should be used only when one of the primary links fail.
To make an example to create a protection link for a 2 x 10 GE links bundle we added a third 10 GE that was actually an EoMPLS running ove the MAN network.
To avoid to have this protection link used in normal conditions we configured the port lacp priority to the highest possible value on both sides.
This can combined with port channel command about minimal links that should be active to decide when the "backup" link is triggered in use.
Hope to help
Giuseppe
