09-03-2017 03:09 PM - edited 03-08-2019 11:55 AM
I'm facing a issue in lacp with nexus 9000v and vIOS
LACP doesn't work at all.
What I observe is that Nexus use destination mac address 00:01:02:03:04:05 for LACP packet.
On the RFC, this should be 01:80:c2:00:00:02 ( and that's the address used by other switches type )
Is this normal ?
Currently only Nexus can negociate LACP with Nexus.....
Solved! Go to Solution.
03-29-2018 03:14 PM
Found this for nxos.7.0.3.I7.3.bin
https://0bin.net/paste/-5tCGc-U-6077INn#PxLYrgY8SosA5V1UMgnBYHWgnTfQj+9FzuIepi70a-G
it actually works:
N9Kv# show lacp counters
Port Sent Recv Recv Sent Pkts Err
port-channel1
Ethernet1/1 8 9 0 0 0
Ethernet1/2 8 9 0 0 0
N9Kv# show int po 1
port-channel1 is up
N9Kv# show version
NXOS: version 7.0(3)I7(3)
03-29-2018 02:26 PM - edited 03-29-2018 02:48 PM
Just curious, trying to apply this fix to nxos.7.0.3.I7.3.bin N9Kv image and it does not work. For which N9Kv version in particular this fix worked for you?
this is what I have at the moment:
port-channel1
Ethernet1/1 1 0 0 0 0
Ethernet1/2 1 0 0 0 0
vIOSL2#show lacp counters
Port Sent Recv Sent Recv Sent Recv Pkts Err
Channel group: 1
Gi0/0 4 1 0 0 0 0 0
Gi0/1 4 1 0 0 0 0 0
so, vIOSL2 actually can recognise LACP packets detined to 00:01:02:03:04:05 mac address, but N9Kv ignores LACP packets destined to 01:80:c2:00:00:02
03-29-2018 03:14 PM
it actually works:
port-channel1
N9Kv# show int po 1
port-channel1 is up
N9Kv# show version
