Lacp Layer 3 Etherchannel
Alek1
Hey,
I am doing a project for school and i have to configure Etherchannel. I am trying to configure layer 3 channel between Cisco iol and Aruba CX in Eve-ng.
Cisco(e1/0-3) -------------------Aruba(1/1/5-8)
When I configure them for some reason on Cisco switch interface 1/0 and 1/1 are working but 1/2 and 1/3 are suspended, on Aruba 1/1/5 and 1/1/6 are blocked/suspended but 1/1/7 and 1/1/8 are working.
When I do on same switches, Cisco on Cisco and Aruba on Aruba, everything works and I can ping but only when I do Cisco and Aruba somethings wrong.
Below is configuration of Cisco and Aruba
Cisco:
interface port-channel 1
no switchport
ip address 192.168.0.1 255.255.255.0
no shutdown
exit
interface range ethernet 1/0-3
no switchport
channel-group 1 mode active
no shutdown
exit
Switch(config)#do show etherchannel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use N - not in use, no aggregation
f - failed to allocate aggregator
M - not in use, minimum links not met
m - not in use, port not aggregated due to minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 1
Number of aggregators: 1
Group Port-channel Protocol Ports
1 Po1(RU) LACP Et1/0(P) Et1/1(P) Et1/2(s)
Et1/3(s)
Aruba:
interface lag 1
ip address 192.168.0.2 255.255.255.0
lacp mode active
no shutdown
exit
interface 1/1/5
lag 1
no shutdown
exit
interface 1/1/6
lag 1
no shutdown
exit
interface 1/1/7
lag 1
no shutdown
exit
interface 1/1/8
lag 1
no shutdown
exit
switch(config)# show lacp interfaces
State abbreviations :
A - Active P - Passive F - Aggregable I - Individual
S - Short-timeout L - Long-timeout N - InSync O - OutofSync
C - Collecting D - Distributing
X - State m/c expired E - Default neighbor state
Actor details of all interfaces:
Intf Aggr Port Port State System-ID System Aggr Forwarding
    Name       Id         Pri                       Pri      Key    State
1/1/5 lag1 6 1 ALFOE 08:00:09:8c:5f:a9 65534 1 lacp-block
1/1/6 lag1 7 1 ALFOE 08:00:09:8c:5f:a9 65534 1 lacp-block
1/1/7 lag1 8 1 ALFNCD 08:00:09:8c:5f:a9 65534 1 up
1/1/8 lag1 9 1 ALFNCD 08:00:09:8c:5f:a9 65534 1 up
What am I doing wrong?
Thank you.
Mark Elsen
 - Check this document and or look for examples :
               https://higherlogicdownload.s3.amazonaws.com/HPE/MigratedAssets/VLAN%20and%20Link-Aggregation%20Interoperability%20ArubaOS-switch%20and%20Cisco%20IOS.pdf
 M.
configs look ok, you don't really have many options. What if you set the Aruba side to lacp passive (shut/no shut the lag interface)?
interface lag 1
lacp mode passive
no shutdown
exit
Deepak Kumar
Aruba CX is a virtual switch. Hope you evaluated with changing different parameters as active, & passive, and active & Active.
One thing comes to mind as did you know the maximum limit of member ports of an EtherChannel for this Aruba switch? Did you change this value?
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
Try enabling udld on the physical ports of the lag
int 1/1/5,1/1/6
udld
sh vsx-status
sh vsx-status vsx-peer
Kind Regards
Paul
