05-02-2019 07:04 AM
Dear, I'm trying to create a lacp port channel between a Nexus and ASR 903
Everything work well using a " switchport mode access" while by using the portchannel as Trunk the Portchannel goes down and the interfaces related to it went to suspended state on the Nexus side.
Kindly find below configuration On the ASR router
Interface Te0/0/3 no ip address channel-group 21 mode active exit Interface Te0/0/4 no ip address channel-group 21 mode active exit interface Port-channel21 no ip address load-interval 30 service instance 3500 ethernet description test vlan 1 encapsulation dot1q 3500 rewrite ingress tag pop 1 symmetric bridge-domain 3500 ! service instance 3600 ethernet description test vlan 2 encapsulation dot1q 3600 rewrite ingress tag pop 1 symmetric bridge-domain 3600 ! interface BDI3500 ip address 192.168.243.1 255.255.255.252 end interface BDI3600 ip address 192.168.243.5 255.255.255.252 end
And that is my configuration on My Nexus Switch:
vlan 3500 exit vlan 3600
exit interface port-channel 21 interface Eth 1/23 channel-group 21 mode passive exit interface Eth 1/24 channel-group 21 mode passive exit interface port-channel 1 switchport mode trunk switchport trunk allowed vlan 3500,3600 exit
the show port-channel summary on the Nexus
Nexus# show port-channel summary Flags: D - Down P - Up in port-channel (members) I - Individual H - Hot-standby (LACP only) s - Suspended r - Module-removed S - Switched R - Routed U - Up (port-channel) M - Not in use. Min-links not met -------------------------------------------------------------------------------- Group Port- Type Protocol Member Ports Channel -------------------------------------------------------------------------------- 21 Po21(SD) Eth LACP Eth1/23(s) Eth1/24(s)
What could be the problem ?
05-02-2019 08:58 PM
On quick look and checks required.
interface port-channel 21 interface Eth 1/23 channel-group 21 mode passive <--- change to active and test exit interface Eth 1/24 channel-group 21 mode passive <--- change to active and test exit interface port-channel 1 <--- This should be 21 switchport mode trunk switchport trunk allowed vlan 3500,3600
Do you have VLAN 3500 and 3600 created Locally ?
if you have still issue can you post below out put from both the side
show vlan
show verion
show port-channel summary.
