LACP Question
readymixed1
Level 2
Level 2
I setup LACP on a Cisco 3750-G and a 3Com 4500 switch. I created Port-Channel 1 and ports 1 & 2 are in this Port-Channel. My question is this:
When I type in show int port-channel1 it shows the speed as 1000mb. I thought it would show 2000mb?
Or is LACP just for fail-over and I now need to do Etherchannel on the Cisco switch and Link Aggregation for the 3Com switch?
Thanks in advanced.
5 Replies 5
ropethic
Level 8
Level 8
It should show 2G. see attached link http://www.cisco.com/en/US/docs/ios/12_2sb/feature/guide/gigeth.html#wp1113400
There are only three valid combinations to run the LACP link aggregate, as follows:
on - on not recommended, ling agg occurs without lacp
active - active - recommended
active - passive - Link aggregation occurs if negotiation is successful.
By default LACP channel mode is passive
Here's the commands I used:
interface range gi5/0/1 - 2
channel-group 1 mode active
channel-protocol lacp
switchport mode trunk
Is that not right?
when I do show interfaces for port-channel1:
Port-channel1 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 001c.5778.4201 (bia 001c.5778.4201)
MTU 1500 bytes, BW 2000000 Kbit, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 0/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is unknown
input flow-control is off, output flow-control is unsupported
Members in this channel: Gi5/0/1 Gi5/0/2
Last input 00:00:01, output 00:00:01, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
36506 packets input, 2872547 bytes, 0 no buffer
Received 36008 broadcasts (34322 multicasts)
0 watchdog, 34322 multicast, 0 pause input
765785 packets output, 139672323 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
It doesn't show this part:
No. of active members in this channel: 2
Member 0 : GigabitEthernet3/0/0 , Full-duplex, 1000Mb/s Member 1 : GigabitEthernet7/1/0 ,
When I do show etherchannel port channel:
show etherchannel port-channel
Channel-group listing:
Group: 1
Port-channels in the group:
Port-channel: Po1 (Primary Aggregator)
Age of the Port-channel = 0d:20h:45m:18s
Logical slot/port = 10/1 Number of ports = 2
HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = LACP
Port security = Disabled
Ports in the Port-channel:
Index Load Port EC state No of bits
0 00 Gi5/0/1 Active 0
0 00 Gi5/0/2 Active 0
Does anyone know what's up?
Also I see I didn't assign my port channel an IP address. Do I need to and why? It seems to be working without and IP address but I just won't show bw @ 2gb and it won't show members of the port-channel and they in etherchannel port-channel it does.
Help please
Thanks in advanced.
archari
Check if all member ports have actually become members in the first place
"show etherchannel"
Ok so I took 5/1 and 5/2 out of port-channel1 to tried to create a new port channel3 and assign it an ip address like its talking about in the article. But in my 3750G it doesn't allow me to assign an IP address to my port-channel3.
Why do i need to assign an ip address?
You dont HAVE to assign an IP address. Do you want a Layer 2 trunk/access kind of etherchannel or a Layer 3 routed etherchannel?
