LACP with AccessPoint does not work correctly
martijn.deleur
Hi there
I have the following problem.
We have several Cisco Catalyst 9200L with 4x 10G uplink in use. The devices are provided with several VLANs and almost everything works perfectly. The problem i have is with LANCOM AccessPoints witch should support LACP (LANCOM LN-1702) This is an AC-Wave2 access point that has two Ethernet ports. The two ports are combined into a bundle. On the switch, I have configured port channel and the required VLANs. The devices get an IP Adress successfully in the native VLAN but Clients who want to connect to WiFi-Networks (tagged VLANs) can't get an IP Adress.
Can anyone help me further?
The current switch config is attached.
Here is additional information:
VLAN50 native = management VLAN (access point and controller, IP management with DHCP)
VLAN54 tagged VLAN with RAIDUS authentication
VLAN55 tagged VLAN with WPA2 key
VLAN56 tagged VLAN with HotSpot Wifi
DHCP pool has 1000 IPs and there are about 100 assigned.
I suspect that there is a problem in the configuration with LACP and Trunk on the switch.
on a side note, looking at the LANCOM port table configuration page (linked below), make sure both ports are in hybrid (mixed) mode and that the port VLAN ID is set to 50 (in order to match the native VLAN on the Cisco side).
I don't see an option to specify which VLANs are allowed on the ports other than allowing all Vlans. What if you change the trunks on the Catalyst to allow all Vlans instead of just the 4 you have specified ?
https://www.lancom-systems.de/docs/config/en/refmanual/#topics/aa1084328.html
12 Replies 12
Deepak Kumar
As per the quick start guide, this AP is supporting the LACP. Can you share some more information as Port-channel summery and LACP status on the particular port/EtherChannel?
Also, we may require an AP configuration screenshot because I hope you are making some mistakes with AP configuration.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello, thanks for the information.
I have put together the following information in the attached file:
LACP Counter, Internal and Neighbor, Port Channel Details, Port Status and PowerInline. (Those are TXT and PDF Files)
Currently, only ports 35 and 36 are configured as port channel 4 and are in operation.
Everything seems fine but VLAN configuration is missing in the AP configuration. Please share the same and also attached. Sho interface trunk output from the switch also.
Deepak Kumar,
Mark Elsen
 - For starters , does it work with a none-LACP setup?
    M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
yes, if I have not configured a port channel, but the VLANs are the same everything works fine.
As asked above, I will provide the configuration of the AP.
Hello
That switch is acting as a distribution switch not a L3 switch so where does you dhcp server reside if isn't off any of your L3 interfaces then you’ll need relay agents applied, Do you have any applied on the l3 interfaces of the wlan and data vlans?
Also do the APs themselves receive dhcp allocation if so then I would say your port config is okay , Are these APs autonomous or lightweight?
Kind Regards
Paul
Hi @paul driver
You had caught a good point on the DHCP relay configuration. Yes, you might be correct.
Please check DHCP Relay (IP helper-address) configuration under the other VLANs, if the DHCP server is seating in different VLANs.
Deepak Kumar,
Hi there @paul driver and @Deepak kumar )
We have a DHCP Server in each VLAN. Also when i don't use Port-Channel at all and use the AccessPoint only with one Uplink (Port Config below) everything works fine.
interface GigabitEthernet1/0/35
description WLAN
switchport trunk native vlan 50
switchport trunk allowed vlan 50,54-56
switchport mode trunk
So do i have to use IP-Helper because of trying to use Port-Channel to increase Network-Speed on the AccessPoint?
I will now do more tests and also check the AP configuration (VLAN etc.) and then post an update again.
Hello
No you do not require any dhcp relay appending to your trunks, try recreating the port-channel without LACP, just using a static port channel configuration and test again.
int x/x/
channel-group x mode on
Kind Regards
Paul
Have you tried a port-channel with Mode ON or passive?
interface range GigabitEthernet1/0/35 - 1/0/36
Deepak Kumar,
Hi there. I think your post get me to the solution. I had to add all used VLANs on the AccessPoint to the "VLAN Table" and added on the Switch-Ports "channel-mode lacp". Now everything seems to work fine. When i start big Up- and Downloads the Counters on de Switchports are going similar.
i think its a bit strange because this vlan table seems not to be used when you don't use LACP. The same VLAN Table is filled in on the controller of the AccessPoints but is not applied to the AccessPoint. I had to do this adjustment manually on all AccessPoints.
