LACP with Sun CP3140 Switch (Port-Channel won't come up)
kasiddiq
Group,
I am trying to setup a Port-Channel between Cisco 7600 and Sun CT900 which has CP3140 switch, but it is not working.
It seems that Sun switch is sending "Fast" LACPDUs while Cisco 7600 is sending "Slow" LACPDUs (as shown below).
Is there a way to force Cisco 7600 to send "fast" LACPDUs.
C7606-1#show lacp 11 neighbor
Flags: S - Device is requesting Slow LACPDUs
F - Device is requesting Fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
Channel group 11 neighbors
Partner's information:
Partner Partner LACP Partner Partner Partner Partner Partner
Port Flags State Port Priority Admin Key Oper Key Port Number Port State
Gi3/2 FA - 128 0x0 0x4A 0x12 0x77
Gi3/4 FA - 128 0x0 0x4A 0x14 0x77
C7606-1#show lacp 11 internal
Channel group 11
LACP port Admin Oper Port Port
Port Flags State Priority Key Key Number State
Gi3/2 SA - 32768 0xB 0xB 0x302 0x5
Gi3/4 SA - 32768 0xB 0xB 0x304 0x5
C7606-1#
Configuration on Cisco 7600 is:
interface Port-channel11
switchport
switchport trunk native vlan 1220
switchport trunk allowed vlan 1220,1240
switchport mode trunk
no ip address
end
interface GigabitEthernet3/2
switchport
no ip address
speed 1000
duplex full
channel-protocol lacp
channel-group 11 mode active
end
interface GigabitEthernet3/4
switchport
no ip address
speed 1000
duplex full
end
htarra
Level 4
Level 4
On 7600 with version 12.2(18)SXE1, once the port-channel is applied to the interface, the links need to be shut and no shut in order to bring the port channel up on the links or interface. And LACP with Sun CP3140 Switch is not possible.
