LAN Computers Always Disconnect Every 10 Minutes!
Ralph Rankin
Hi Experts,
i'm newbie in a cisco switch and i need help or advice how to fix this problem.
i'm using 2960 cisco switch and every department has a switch same model, i have noticed that every 10 to 15 minutes my network is disconnected for atleast 10 seconds and all client conneted to the server was disconnected also. please help how to fix this...
Thanks..
Ralph
3 Accepted Solutions
    Could you please input the command "sh spanning-tree vlan 1 detail" in each switch and show us the output ?
Hello Raffy,
Is this your Core switch ?
Looks like you have some looping in your network.
What is plugged in to port FastEthernet0/12 ?
If you can, unplug the device and see how the network behaves.
If it is another production switch, do "sh spanning-tree vlan 1 detail" and post the results. If it is not a Cisco switch, check for any physical loops on the ports.
Let me know what you find.
Please don't forget to rate useful posts..
Shamal
Check each port on that switch. Look for any physical loops. Also make sure this switch has STP turned on ( You should find the setting somewhere in the GUI )
At this point ( based on your earlier post ) your STP root is the SG switch. This should not be the case. With your Topology, your STP root should be your core switch.
In Core switch's CLI, Add the following command in global configuration mode
spanning-tree vlan 1 root primary
This should make your core switch the root.
After that leave it for about 1 hour and post another "show spannig-tree vlan 1"
Shamal
29 Replies 29
Leo Laohoo
Can you clarify further?  Are you saying that ALL computers disconnect every 10 to 15 minutes or this issue is observed to SOME computers.
yes sir all computer accessing to the server was diconnect and then resume after 10 seconds. im using Cisco Network Assistant to figure out some errors, ived found that 1 switch has FCS errors 1059 total and Collision Frament 110 total and still increasing, what is this means sir? thanks
Hello Raffy,
If you know how to check the CPU utilization of your switches, Can you please let us know the number for each switch..
Also can you check your core switch's up-time and let us know ?
Shamal
Core Switch
CPU Utilization = 4%
Memory = 29%
SW1
Memory = 28%
SW2
CPU Utilization = 5%
Memory = 28%
SW3
CPU Utilization = 14%
Memory = 64%
thats all sir.
Ok Raffy, few more questions.
When you say ALL computers get disconnected, did you detect a pattern?  Like all computers connected to one physical switch getting disconnected?
In addition to leolaohoo's question, Can you get the uptime of each switch using Network Assistant or may be do a "show version" for each switch and post the outputs ( If you have CLI access )?
@Sir leolaoho the ALL computer accessing the server is in deffirent switches. i do ping for monitoring the different switches inlude some clients where they belong, but also same result disconnect all of them at the sametime. ived tried also to connect direcly to core switch but same result ived got..
@Sir Shamai
ived recently purchase this 3 switches with same version and model. but i will check to post here. thanks..
Additional Info.
Device Type - WS-c2960-24TC-S
Current Version - 12.2(50)SES -CRYPTO (On 3 Switches)
Current Version - 12.2(55)SE5 - LAN-BASE-CRYPTO (1 Switch)
Hi Raffy,
I asked for the "show version" because it gives you the uptime of the switch. Can you check the uptime of the each switch, this way we can make sure none of them are crashing.. and we can rule that out..
Hi Shamal,
here is the show version if different switch.
rdrdcswitch1>show version
Cisco IOS Software, C2960 Software (C2960-LANLITEK9-M), Version 12.2(50)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 28-Sep-10 13:44 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44r)SE4, RELEASE SOFTWARE (fc1)
rdrdcswitch1 uptime is 2 days, 1 hour, 3 minutes
System image file is "flash:c2960-lanlitek9-mz.122-50.SE5/c2960-lanlitek9-mz.122-50.SE5.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960-24TC-S (PowerPC405) processor (revision N0) with 65536K bytes of memory.
Processor board ID FCQ1612X2KA
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 5C:50:15:AA:43:80
Motherboard assembly number     : 73-11472-10
Power supply part number        : 341-0097-03
Motherboard serial number       : FCQ16110MWK
Power supply serial number      : DCA160780YZ
Model revision number           : N0
Motherboard revision number     : A0
Model number                    : WS-C2960-24TC-S
System serial number            : FCQ1612X2KA
Top Assembly Part Number        : 800-29857-05
Top Assembly Revision Number    : C0
Version ID                      : V07
CLEI Code Number                : COMCV00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 26    WS-C2960-24TC-S    12.2(50)SE5           C2960-LANLITEK9-M
Configuration register is 0xF
rdrdcswitch2>show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(55)SE5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Thu 09-Feb-12 19:11 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x01900000
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(53r)SEY3, RELEASE SOFTWARE (fc1)
rdrdcswitch2 uptime is 2 days, 1 hour, 11 minutes
System image file is "flash:/c2960-lanbasek9-mz.122-55.SE5/c2960-lanbasek9-mz.122-55.SE5.bin"
export@cisco.com.
cisco WS-C2960-24TC-L (PowerPC405) processor (revision V0) with 65536K bytes of memory.
Processor board ID FCQ1645X3NW
Base ethernet MAC Address       : CC:D5:39:7A:AF:00
Motherboard assembly number     : 73-12599-06
Motherboard serial number       : FCQ16440N48
Power supply serial number      : DCA164083PG
Model revision number           : V0
Model number                    : WS-C2960-24TC-L
System serial number            : FCQ1645X3NW
Top Assembly Part Number        : 800-32796-02
Top Assembly Revision Number    : A0
Version ID                      : V11
CLEI Code Number                : COM3K00BRF
Hardware Board Revision Number  : 0x0A
*    1 26    WS-C2960-24TC-L    12.2(55)SE5           C2960-LANBASEK9-M
rdrdcswitch3>show version
rdrdcswitch3 uptime is 2 days, 1 hour, 6 minutes
export@cisco.com.
Processor board ID FCQ1611Y27Z
Base ethernet MAC Address       : 5C:50:15:56:7E:00
Motherboard serial number       : FCQ16100LGF
Power supply serial number      : DCA1607836H
System serial number            : FCQ1611Y27Z
Version ID                      : V07
Sir,
how to check logs? thanks
Raffy,
This sounds like something is happening in your core switch.  Console into the core switch and check the logs for anything suspicous.
Can you provide your network topology diagram (cable connectivity with CORE and other switches), also type of STP configured on all switches, CORE may have custom STP but 2960 may have PVST (Default).
Hi Bharat,
I don't configure STP. this problem exist 1 week ago and i don not made any changes on my network.
