LAN Computers Always Disconnect Every 10 Minutes!
Ralph Rankin
Hi Experts,
i'm newbie in a cisco switch and i need help or advice how to fix this problem.
i'm using 2960 cisco switch and every department has a switch same model, i have noticed that every 10 to 15 minutes my network is disconnected for atleast 10 seconds and all client conneted to the server was disconnected also. please help how to fix this...
Thanks..
Ralph
29 Replies 29
Hi Raffy,
Your switched doesn't seem to have crashed.  As Bharath said, do you have a network diagram ?
Also, you mentioned that about week a this problem started, So about week a go, did you plug in some new device/pc in to one of the switches, or may be a new employee started there ?? anything ?
Shamal
Sounds like stp to me. Any non-Cisco switches or virtual servers with trunk ports attached to this network? You need to post the running config of the switches.
@Jeff
yes i have non cisco switch connected to my network.
here is my running-config on core switch.
rdrdcswitch1#show running-config
Building configuration...
Current configuration : 6990 bytes
version 12.2
no service pad
service password-encryption
hostname rdrdcswitch1
boot-start-marker
boot-end-marker
logging buffered 64000
enable secret 5 $1$1oGz$HYOCvATFvxlgyMeuAVSxe.
no aaa new-model
system mtu routing 1500
udld aggressive
ip subnet-zero
no ip domain-lookup
mls qos srr-queue output cos-map queue 1 threshold 3 5
mls qos srr-queue output cos-map queue 2 threshold 3 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 2 4
mls qos srr-queue output cos-map queue 4 threshold 2 1
mls qos srr-queue output cos-map queue 4 threshold 3 0
mls qos
crypto pki trustpoint TP-self-signed-363479936
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-363479936
revocation-check none
rsakeypair TP-self-signed-363479936
crypto pki certificate chain TP-self-signed-363479936
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363334 37393933 36301E17 0D393330 33303130 30303130
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3336 33343739
  39333630 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  B49B374B 5105B598 6D15D58D 99C01F02 763E3919 2593A610 52815F8A 18E79CEA
  821F8249 810B8657 FAE10F26 02CB0808 6C02FD7D 858E49F9 D098ACA5 4AB63AF6
  A8618045 6B2604F9 A3BEBFFF A4AC2BA2 10C9416B 27DEE0C4 1CCB9B57 AF79CE04
  46AB9D2C 1C5AFC29 EE1BFB5E 961E6E14 39D56BF5 AA01E90C 99117B2E D542CA8B
  02030100 01A36D30 6B300F06 03551D13 0101FF04 05300301 01FF3018 0603551D
  11041130 0F820D72 64726463 73776974 6368312E 301F0603 551D2304 18301680
  14808E94 0004D418 E1D441DE 3C8B7C8A 4241DAFB BF301D06 03551D0E 04160414
  808E9400 04D418E1 D441DE3C 8B7C8A42 41DAFBBF 300D0609 2A864886 F70D0101
  04050003 81810054 85406059 FF74B516 5F3E42CF 53FCBE26 5387B7D0 4C02200B
  125DC968 7020F8F4 D56D9EA1 287D863F 5F04CCEF AFAD5D36 8272C313 FBA5D1B0
  75936F5F 8CD72731 44669EC4 BFBAEC3F 25205346 0664E322 CC95201A 346A7801
  5E4669CD D6ABCEAA 7999ECFA 85FAEFDD 5638103B 3EFB6910 BB99A928 11CCDFF9
  8FEE4AA7 E68DEB
  quit
macro global description cisco-global | cisco-global | cisco-global
errdisable recovery cause link-flap
errdisable recovery interval 60
spanning-tree mode rapid-pvst
spanning-tree loopguard default
vlan internal allocation policy ascending
interface FastEthernet0/1
description SAP
storm-control broadcast level 80.00
interface FastEthernet0/2
description Barter
switchport mode access
switchport port-security
switchport port-security aging time 2
switchport port-security violation restrict
switchport port-security aging type inactivity
macro description cisco-desktop
spanning-tree portfast
spanning-tree bpduguard enable
interface FastEthernet0/3
description MRS
interface FastEthernet0/4
description IBMx3250 pot1
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
description WiFi 2F
switchport mode trunk
mls qos trust cos
macro description cisco-wireless
interface FastEthernet0/10
description Domain
interface FastEthernet0/11
interface FastEthernet0/12
description Dolores Hotel Link
mls qos trust cos
macro description cisco-switch
storm-control broadcast level 60.00
storm-control multicast level 60.00
storm-control unicast level 60.00
spanning-tree link-type point-to-point
interface FastEthernet0/13
description RDH Acharon
interface FastEthernet0/14
description RDH Santiago
interface FastEthernet0/15
description Firewall
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
description HR
speed 100
duplex full
mls qos trust cos
interface GigabitEthernet0/1
description Accounting
mls qos trust cos
spanning-tree portfast trunk
interface GigabitEthernet0/2
interface Vlan1
ip address 192.168.8.95 255.255.255.0
no ip route-cache
ip default-gateway 192.168.8.1
no ip http server
ip http secure-server
control-plane
switch2
rdrdcswitch2#show running-config
Current configuration : 6571 bytes
version 12.2
no service pad
hostname rdrdcswitch2
boot-start-marker
boot-end-marker
no aaa new-model
udld aggressive
no ip domain-lookup
mls qos map cos-dscp 0 8 16 24 32 46 48 56
mls qos srr-queue input bandwidth 70 30
mls qos srr-queue input threshold 1 80 90
mls qos srr-queue input priority-queue 2 bandwidth 30
mls qos srr-queue input cos-map queue 1 threshold 2 3
mls qos srr-queue input cos-map queue 1 threshold 3 6 7
mls qos srr-queue input cos-map queue 2 threshold 1 4
mls qos srr-queue input dscp-map queue 1 threshold 2 24
mls qos srr-queue input dscp-map queue 1 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue input dscp-map queue 1 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue input dscp-map queue 2 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue input dscp-map queue 2 threshold 3 46 47
mls qos srr-queue output cos-map queue 1 threshold 3 4 5
mls qos srr-queue output cos-map queue 2 threshold 1 2
mls qos srr-queue output cos-map queue 2 threshold 2 3
mls qos srr-queue output cos-map queue 2 threshold 3 6 7
mls qos srr-queue output cos-map queue 3 threshold 3 0
mls qos srr-queue output cos-map queue 4 threshold 3 1
mls qos srr-queue output dscp-map queue 1 threshold 3 32 33 40 41 42 43 44 45
mls qos srr-queue output dscp-map queue 1 threshold 3 46 47
mls qos srr-queue output dscp-map queue 2 threshold 1 16 17 18 19 20 21 22 23
mls qos srr-queue output dscp-map queue 2 threshold 1 26 27 28 29 30 31 34 35
mls qos srr-queue output dscp-map queue 2 threshold 1 36 37 38 39
mls qos srr-queue output dscp-map queue 2 threshold 2 24
mls qos srr-queue output dscp-map queue 2 threshold 3 48 49 50 51 52 53 54 55
mls qos srr-queue output dscp-map queue 2 threshold 3 56 57 58 59 60 61 62 63
mls qos srr-queue output dscp-map queue 3 threshold 3 0 1 2 3 4 5 6 7
mls qos srr-queue output dscp-map queue 4 threshold 1 8 9 11 13 15
mls qos srr-queue output dscp-map queue 4 threshold 2 10 12 14
mls qos queue-set output 1 threshold 1 100 100 50 200
mls qos queue-set output 1 threshold 2 125 125 100 400
mls qos queue-set output 1 threshold 3 100 100 100 400
mls qos queue-set output 1 threshold 4 60 150 50 200
mls qos queue-set output 1 buffers 15 25 40 20
mls qos
no setup express
crypto pki trustpoint TP-self-signed-964341504
subject-name cn=IOS-Self-Signed-Certificate-964341504
rsakeypair TP-self-signed-964341504
crypto pki certificate chain TP-self-signed-964341504
  69666963 6174652D 39363433 34313530 34301E17 0D393330 33303130 30303135
  335A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3936 34333431
  35303430 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  AFC86641 03403B2F BC5850E2 10F56703 8262479D DBF4A23D 7E960537 A2DFBF13
  FDA939A0 CC7F1011 6632A960 1E584E8C 7D66837E 66E662D3 978EA055 F9B3F61E
  07C14FDF E92D1861 75C8EF3E FBAD510B A615F7D1 0CB4AE52 DC4ED1CD F50233E8
  1CAC32BA 314FEAB4 B398F60A CC13861C DA5A701E D0EEEF9C A00560DE 1D36CA51
  11041130 0F820D72 64726463 73776974 6368322E 301F0603 551D2304 18301680
  14CE61A0 F9E3D9DC 801793C3 AD668AF6 10AB16F5 90301D06 03551D0E 04160414
  CE61A0F9 E3D9DC80 1793C3AD 668AF610 AB16F590 300D0609 2A864886 F70D0101
  04050003 818100A1 D4E3BE5A E2AF82CA 9A2C503A 343E37E6 C75084A8 6B35E96A
  F141866E 64BA0D0E E64F9A23 DDBCA7A7 78CC3C08 C30BF56F 4561F46F 1AD08507
  F5202A43 7A3D6002 3BB9E036 86500356 4C0ADE19 A10C650F 020C2EBD DA733658
  52C87EDC 9D5FD443 B76E8016 6A613CC9 A82F9A67 10FC83D2 0282D474 8C39A56C
  FAA8C0D3 C726F8
  quit
auto qos srnd4
speed 100
duplex full
description To Richmond
speed 100
duplex full
srr-queue bandwidth share 1 30 35 5
priority-queue out
mls qos trust cos
auto qos trust
interface Vlan1
ip address 192.168.8.98 255.255.255.0
no ip route-cache
ip http server
Switch 3
rdrdcswitch3#show run
rdrdcswitch3#show running-config
Current configuration : 10312 bytes
version 12.2
no service pad
hostname rdrdcswitch3
boot-start-marker
boot-end-marker
no aaa new-model
udld aggressive
ip subnet-zero
no ip domain-lookup
mls qos
crypto pki trustpoint HTTPS_SS_CERT_KEYPAIR
serial-number
rsakeypair HTTPS_SS_CERT_KEYPAIR
crypto pki certificate chain HTTPS_SS_CERT_KEYPAIR
  30820271 308201DA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  47311630 14060355 0403130D 72647264 63737769 74636833 2E312D30 0F060355
  04051308 31353536 37453030 301A0609 2A864886 F70D0109 02160D72 64726463
  73776974 6368332E 301E170D 39333033 30323132 34343134 5A170D32 30303130
  31303030 3030305A 30473116 30140603 55040313 0D726472 64637377 69746368
  332E312D 300F0603 55040513 08313535 36374530 30301A06 092A8648 86F70D01
  0902160D 72647264 63737769 74636833 2E30819F 300D0609 2A864886 F70D0101
  01050003 818D0030 81890281 8100B709 970BCFF3 73188541 65D13893 3C041170
  FC85F79D CBE21468 3A434FA7 1DB81A5E 25829E91 951D533D 08421267 D41955C9
  65276DFA 569CFA8E D3E7C5B4 C60EB9C5 A1414CD9 9C688CC3 8EA796E3 354A9980
  8366A1E1 402630FB F2CF80B0 31329B95 562E8AF8 A2F5E7BB 66D68574 C7B5D59D
  277F1B4D 32B9C94D 37E4A0FD 6C2B0203 010001A3 6D306B30 0F060355 1D130101
  FF040530 030101FF 30180603 551D1104 11300F82 0D726472 64637377 69746368
  332E301F 0603551D 23041830 16801418 0F7EEC0D D5A08705 70CD4685 35929D2A
  021D0930 1D060355 1D0E0416 0414180F 7EEC0DD5 A0870570 CD468535 929D2A02
  1D09300D 06092A86 4886F70D 01010405 00038181 00378ACA 62575EE7 F30374E3
  88A66B32 ABDE5916 BFE84E17 5365F418 754F9911 0A3B6E54 0A8CACEE B9EF3FFF
  2EE4D9E2 9615D6FB 3CE94E28 7FE9A171 A898A0C6 6CCB2C54 59584894 1AB01805
  383E3B60 2E28CA39 6F4A2763 BEDBE95E A31E4EDF E9BBF818 66CA0BBE FB771B39
  B0E5C390 83D57A40 DF3E30BC 970A9A1E 1F79573B 20
  quit
storm-control broadcast level 30.00
storm-control multicast level 30.00
storm-control unicast level 30.00
mls qos trust cos
macro description cisco-router
mls qos trust cos
interface Vlan1
ip address 192.168.8.97 255.255.255.0
no ip route-cache
ip http server
control-plane
Switch4
RDHSantiago#show ru
RDHSantiago#show running-config
Current configuration : 7471 bytes
version 12.2
no service pad
hostname RDHSantiago
boot-start-marker
boot-end-marker
no aaa new-model
udld aggressive
ip subnet-zero
no ip domain-lookup
no setup express
serial-number
  3082026C 308201D5 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  45311530 13060355 0403130C 52444853 616E7469 61676F2E 312C300F 06035504
  05130837 35463739 35303030 1906092A 864886F7 0D010902 160C5244 4853616E
  74696167 6F2E301E 170D3933 30333031 30303034 34345A17 0D323030 31303130
  30303030 305A3045 31153013 06035504 03130C52 44485361 6E746961 676F2E31
  2C300F06 03550405 13083735 46373935 30303019 06092A86 4886F70D 01090216
  0C524448 53616E74 6961676F 2E30819F 300D0609 2A864886 F70D0101 01050003
  818D0030 81890281 8100E14B 6719BBF3 2AAC6AF9 06A576DB 53169CD4 B7B86F6E
  D1914A1F 13CB7AD0 8FBB6E78 00453003 6E26AFF3 FA700EDA 5E208447 C43073FB
  3A97695C 1A45088B C807A6CB 2DFDD9EA 2595F3C2 9F22EE06 55B5AFA3 7A9EB629
  EEB93D61 EFE1972A 19EF0376 AD7C4690 39EA7B60 7C7F0F48 0B24B931 9F61DA7E
  B198BE6D 9CF2E7A7 14F50203 010001A3 6C306A30 0F060355 1D130101 FF040530
  030101FF 30170603 551D1104 10300E82 0C524448 53616E74 6961676F 2E301F06
  03551D23 04183016 80141499 BC466167 C00F6C1E 3275ED9F EB41B9C5 BA9A301D
  0603551D 0E041604 141499BC 466167C0 0F6C1E32 75ED9FEB 41B9C5BA 9A300D06
  092A8648 86F70D01 01040500 03818100 055E4EEB 47394AF4 5E3716C6 80A0E450
  9E11B86C ABD100DE 909ECD04 C102D1BD 9B65201B 490BA13C 965CC8D4 C6B1AA0E
  D8424424 C99072C8 36FAC4DA FD4F4D65 C8FFA8B9 B5D5F0E3 6D4DF7A6 D44AB088
  05BA69DB 09ECBE2C D88D6AC1 BB6F4622 8AF9C2B1 4A4AA519 492C03D3 59900DDA
  DF41FE88 7DBBF46B A7CF347C 206F89B9
  quit
description To GF
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
shutdown
interface Vlan1
ip address 192.168.8.96 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
control-plane
    Could you please input the command "sh spanning-tree vlan 1 detail" in each switch and show us the output ?
SW1>sh spanning-tree vlan 1 detail
VLAN0001 is executing the rstp compatible Spanning Tree protocol
  Bridge Identifier has priority 32768, sysid 1, address ccd5.397a.af00
  Configured hello time 2, max age 20, forward delay 15, transmit hold-count 6
  Current root has priority 32768, address 6c50.4d4d.32dc
  Root port is 12 (FastEthernet0/12), cost of root path is 19
  Topology change flag not set, detected flag not set
  Number of topology changes 237 last change occurred 00:23:45 ago
          from GigabitEthernet0/1
  Times:  hold 1, topology change 35, notification 2
          hello 2, max age 20, forward delay 15
  Timers: hello 0, topology change 0, notification 0, aging 300
Port 1 (FastEthernet0/1) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.1.
   Designated root has priority 32768, address 6c50.4d4d.32dc
   Designated bridge has priority 32769, address ccd5.397a.af00
   Designated port id is 128.1, designated path cost 19
   Timers: message age 0, forward delay 0, hold 0
   Number of transitions to forwarding state: 142
   The port is in the portfast mode
   Link type is point-to-point by default
   Bpdu guard is enabled
   Loop guard is enabled by default on the port
   BPDU: sent 78969, received 0
Port 2 (FastEthernet0/2) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.2.
   Designated port id is 128.2, designated path cost 19
   BPDU: sent 78975, received 0
Port 3 (FastEthernet0/3) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.3.
   Designated port id is 128.3, designated path cost 19
   BPDU: sent 78977, received 0
Port 4 (FastEthernet0/4) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.4.
   Designated port id is 128.4, designated path cost 19
   BPDU: sent 78978, received 0
Port 7 (FastEthernet0/7) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.7.
   Designated port id is 128.7, designated path cost 19
   BPDU: sent 78979, received 0
Port 8 (FastEthernet0/8) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.8.
   Designated port id is 128.8, designated path cost 19
   Number of transitions to forwarding state: 9
   BPDU: sent 2404, received 0
Port 9 (FastEthernet0/9) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.9.
   Designated port id is 128.9, designated path cost 19
   Number of transitions to forwarding state: 34
   BPDU: sent 78332, received 0
Port 10 (FastEthernet0/10) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.10.
   Designated port id is 128.10, designated path cost 19
   BPDU: sent 78982, received 0
Port 12 (FastEthernet0/12) of VLAN0001 is root forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.12.
   Designated bridge has priority 32768, address 6c50.4d4d.32dc
   Designated port id is 128.56, designated path cost 0
   Timers: message age 16, forward delay 0, hold 0
   Number of transitions to forwarding state: 45
   BPDU: sent 170, received 78165
Port 13 (FastEthernet0/13) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.13.
   Designated port id is 128.13, designated path cost 19
   BPDU: sent 79051, received 0
Port 14 (FastEthernet0/14) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.14.
   Designated port id is 128.14, designated path cost 19
   BPDU: sent 77679, received 188
Port 15 (FastEthernet0/15) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.15.
   Designated port id is 128.15, designated path cost 19
   BPDU: sent 78985, received 0
Port 24 (FastEthernet0/24) of VLAN0001 is designated forwarding
   Port path cost 19, Port priority 128, Port Identifier 128.24.
   Designated port id is 128.24, designated path cost 19
   Number of transitions to forwarding state: 46
   BPDU: sent 78182, received 249
Port 25 (GigabitEthernet0/1) of VLAN0001 is designated forwarding
   Port path cost 4, Port priority 128, Port Identifier 128.25.
   Designated port id is 128.25, designated path cost 19
   BPDU: sent 78107, received 1182
Hello Raffy,
Is this your Core switch ?
Looks like you have some looping in your network.
What is plugged in to port FastEthernet0/12 ?
If you can, unplug the device and see how the network behaves.
If it is another production switch, do "sh spanning-tree vlan 1 detail" and post the results. If it is not a Cisco switch, check for any physical loops on the ports.
Let me know what you find.
Please don't forget to rate useful posts..
Shamal
Hi Sir Shamal,
thanks for your reply. yes this is a core switch and
port FastEthernet0/12 is connected to SG 300-10 10-Port Gigabit Managed Switch and it is part of the production. and  its not supported using commandline.
Check each port on that switch. Look for any physical loops. Also make sure this switch has STP turned on ( You should find the setting somewhere in the GUI )
At this point ( based on your earlier post ) your STP root is the SG switch. This should not be the case. With your Topology, your STP root should be your core switch.
In Core switch's CLI, Add the following command in global configuration mode
spanning-tree vlan 1 root primary
This should make your core switch the root.
After that leave it for about 1 hour and post another "show spannig-tree vlan 1"
Shamal
Thanks you so much Sir.
Raffy
Hi Raffy,
Did you find something ? Did it resolve your issue ?
Shamal
Hi Sir,
i found that 1 computer in my network causing this problem. when i'm remove that pc in my network everything work fine. but of coure i did your adviced  regarding spanning tree it will correct some other aspects.
Thanks you.
Raffy
Hi Raffy,
Good to know everything's working fine !
Hello Ralph,
How did you find that PC in your network causing Issues. I am also facing the same issues now. Please suggest me how to resolve.
@sha006sha76189 I know its MUCh farther into the future now, but one tell-tale sign that something is "off" with one (or more?) of your PCs in your network, such as a bad/bent/tweaked Cable or failing NIC is the speed being advertised either jumping up and down or staying very low and/or the duplex showing as "Half" when you did not set any NICs to use Half Duplex.
You can check the speed in the Network Switch config (either SNMP or GUI) by refreshing the page / output every few seconds and looking for changes. Assuming you are using the GUI with a Managed Switch, look for a menu option that is something along the lines of "Port Settings" that is often under "Port Management" (or similar) heading - there should be a "page" that shows all of the connected ports and the speeds being advertised by your NICs to the router.
Note that if any NICs are in devices that are "asleep" they will advertise as lower, too, but any "awake" PCs should be showing as "full 1000M" assuming you are working with a 1Gbe switch/port.
CoolElectricity
I know this is an even older necro than the last, but we wanted to mention that we experienced this "drops every 10 minutes" "blipping" while adding 2 x 10Gbe segments to a Cisco SG200 1Gbe "trunk" switch and we were able to troubleshoot a little easier by clearing the Interface Counters and Etherlike Counters after unplugging LAG ports until only one of the LAG port connections remained.
Similar post from here, too: https://community.cisco.com/t5/switching/port-disables-every-10-minutes/td-p/2006353
It turns out that the issue was using the "middle switch" to connect the other segments/machines was seemingly the issue, as when we switched the port connect to the outtermost 10Gbe switch of the 2 that were added, there were no longer issues with the drops every 10 minutes. When we reconnected all ports for the LAG Group, everything was fine, too. This seems odd since all switches were configured for RSTP, but worth documenting. This presumably also means that there may be issues with any devices connected to switches with 2 or more "hops" from the trunk, which could mean terrible things for certain network designs that have physical space restrictions. So consider testing before purchase and home running!
We hope that helps others that might be keeping these older switches going in homelabs or SOHO situations were they are not directly connected to the public web (too many CVEs...).
