I was given someone else's configuration so i'm trying to figure out how to make it work. They tried to apply an address to the port-channel but the switch won't accept the command.
I thought that i could create a port channel sub-interface but the 2960 won't accept the sub-interface config.
I created a loopback with the address 192.168.253.3 but am not able to ping across to the fw at 192.168.253.2.
I don't have console access to the firewall just the config.
The switch interfaces are up/up and the tech onsite verified that the swtich and the firewall are connected to each other.
I'm open to ideas on how to make it work...if possible... :-)
2960 config (uncorrected)
config t
interface GigabitEthernet1/0/23
description Connection to asa firewall port ge-1/2
no shutdown
interface GigabitEthernet2/0/23
description Connection to asa firewall port ge-1/3
no shutdown
exit
interface port-channel 1
ip address 192.168.253.3 255.255.255.253
switchport mode access
channel-group 1 mode active
exit
do wr
ASA config
interface GigabitEthernet1/2
description Connection to switch 1A port ge-1/0/23
no shutdown
interface GigabitEthernet1/3
description Connection to switch 1B port ge-2/0/23
no shutdown
exit
interface redundant 1
ip address 192.168.253.2 255.255.255.254
member-interface GigabitEthernet1/2
member-interface GigabitEthernet1/3
nameif internal
security-level 100
no shutdown
exit
route internal 192.168.0.0 255.255.0.0 192.168.253.3
