04-05-2017 12:16 PM - edited 03-08-2019 10:04 AM
so I picked up a 2851 router to start dipping into ios test the waters a little. I think I configured it properly but clearly I must be missing something because even though all my lan devices are pulling dhcp ip addresses and can ping the dhcp interface, they can not seem to make the connection over to the wan interface and reach the outside world. here is my config and I feel like I'm missing something that should be right in front of my face but I'm just not seeing it..
Building configuration...
Current configuration : 1155 bytes
version 12.4
hostname skynet
boot-start-marker
boot-end-marker
enable secret 5 $1$z/Eq$UurPEJx3u1NGwzuHuSBQU0
enable password (removed)
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.35
ip dhcp pool insideDHCP
import all
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
voice-card 0
no dspfarm
interface GigabitEthernet0/0
description Facing the ISP (the WAN)
ip address dhcp
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/1
description Facing my LAN
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
interface Serial0/1/0
no ip address
shutdown
interface Serial0/2/0
no ip address
shutdown
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
password (removed)
login
scheduler allocate 20000 1000
end
Solved! Go to Solution.
04-05-2017 12:21 PM
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
ip nat inside source list 101 interface gi0/0 overload
Jon
04-05-2017 12:21 PM
Jon
04-05-2017 01:13 PM
thank you for your time
