LAN interface resets?
willemvwyk
If I have an interface on a switch, why would it have interface resets?
FastEthernet0/2 is down, line protocol is down (notconnect)
Hardware is Fast Ethernet, address is 000c.cec4.0d02 (bia 000c.cec4.0d02)
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Auto-duplex, Auto-speed
0 output errors, 0 collisions, 2 interface resets
Doing a sh contro eth-contr fas 0/2 I don't see any errors on the controller.
wvw
Jagdeep Gambhir
Level 10
Level 10
Interface Resets Gives the number of times that an interface has been completely reset.
This can happen if packets queued for transmission were not sent within several seconds.
On a serial line, this can be caused by a malfunctioning modem that is not supplying the
transmit clock signal, or by a cable problem. If the system notices that the carrier
detect line of a serial interface is up, but the line protocol is down, it periodically
resets the interface in an effort to restart it. Interface resets can also occur when an
interface is looped back or shut down.
