LAN Mess
Ricky S
Level 5
Level 5
Hi folks, we recently acquired a new company and I am trying to get my head wrapped around their network setup until I physically go out there to refresh the network.
I have a bit of a trivial situation and am wandering if someone can help me out.
I have 2 switches: Switch 4 and Switch 5 which are connected to one another over a trunk link
Switch 4 has Gi1/0/2 and Gi1/0/3 attached to a database server via a port channel (Po1). Server IP address is 192.168.218.19
Default Gateway for Switch 4 is Switch 5
When I do a traceroute to 192.168.218.19 from Switch4, trace goes to Switch 5 and then to 192.168.218.19
When I do show mac address-table address command on the MAC address of 192.168.218.19 on Switch 5, it says its connected to Gi1/0/1. Gi1/0/1 is connected to Switch4
When I go back to Switch4 and look up the MAC for 192.168.218.19, it says connected via Po1.
The database server has two NICs connecting to Switch 4 and two Connecting to Switch 5 for backup.
This causes a problem when I have a device connecting directly into Switch 4 and wants to send a file to the database server. It first goes from Switch 4 to Switch 5, then back over the trunk to Switch 4 and to the Po1.
Switch5 must stay as the default gateway for switch 4 as it's got further connectivity into the WAN from Switch 5.
Please advise how I can fix this?
6 Replies 6
Ricky S
Level 5
Level 5
Below is an output of basically everything that I talk about in my previous post, in Cisco's language
Username: xxxx
Password:
SW4>
SW4>en
Password:
SW4#
SW4#traceroute 192.168.218.19
Tracing the route to 192.168.218.19
  1 172.18.6.16 0 msec 0 msec 0 msec
  2 192.168.218.19 0 msec 0 msec 8 msec
SW4#
SW4#
SW4#172.18.6.16
Trying 172.18.6.16 ... Open
User Access Verification
Username: xxxxxxxxx
Password:
SW5>en
Password:
SW5#
SW5#
SW5#sh arp | inc 192.168.218.19
Internet  192.168.218.19        121   0060.163e.49bf  ARPA   Vlan2
SW5#
SW5#
SW5#sh mac address-table address 0060.163e.49bf
          Mac Address Table
Vlan    Mac Address       Type        Ports
   2    0060.163e.49bf    DYNAMIC     Gi1/0/1
Total Mac Addresses for this criterion: 1
SW5#
SW5#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
SW3     Gig 1/0/18        176           S I      WS-C2960G Gig 0/2
SW3     Gig 1/0/20        176           S I      WS-C2960G Gig 0/1
SW4     Gig 1/0/2         149           S I      WS-C3750G Gig 1/0/1
SW4     Gig 1/0/1         154           S I      WS-C3750G Gig 1/0/2
SW5#sh run int gig1/0/1
interface GigabitEthernet1/0/1
description etherchanne to SW4
switchport mode trunk
channel-group 3 mode active
end
SW5#sh run int gig1/0/2
interface GigabitEthernet1/0/2
end
SW5#
SW5#sh run int po3
interface Port-channel3
end
SW5#
SW5#exit
[Connection to 172.18.6.16 closed by foreign host]
SW4#
SW4#sh mac address-table address 0060.163e.49bf
          Mac Address Table
   2    0060.163e.49bf    DYNAMIC     Po5
   1    0060.163e.49bf    DYNAMIC     Po5
Total Mac Addresses for this criterion: 2
SW4#
SW4#sh etherchannel summary
Flags:  D - down        P - in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 4
Number of aggregators:           4
Group  Port-channel  Protocol    Ports
1      Po1(SD)         LACP      Gi1/0/24(I)
2      Po2(SD)          -
3      Po3(SU)         LACP      Gi1/0/1(P)
5      Po5(SU)         LACP      Gi1/0/3(P)  Gi1/0/4(P)
SW4#sh run int gi1/0/3
Building configuration...
Current configuration : 157 bytes
interface GigabitEthernet1/0/3
description EMC_Active cge1
channel-group 5 mode active
end
SW4#sh run int gi1/0/4
interface GigabitEthernet1/0/4
description EMC_Active cge2
end
SW4#sh run int po5
Current configuration : 92 bytes
interface Port-channel5
end
Aileron88
Level 5
Level 5
Could you provide a diagram of this setup? What switches are you using?
Adam
Hi Adam, I quickly created a drawing as per your note. It's not a master-piece but it sort of will help put things into perspective.
ORANGE lines and arrows show how traffic flows from a client to the server currently.
GREEN lines and arrows show how it should be flowing.
Can you provide your running from sw4 and sw5 as well as ip config from client and server.
Regards.
Alain
Hi Alain, here are the configs. Thanks.
SWITCH 4
SW4#sh run
Current configuration : 3537 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname SW4
enable secret xxxxxxxxx
username xxxxxxxxx password xxxxxxxxxxx
no aaa new-model
clock timezone UTC -5
clock summer-time UTC recurring
switch 1 provision ws-c3750g-24t
system mtu routing 1500
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface Port-channel1
interface Port-channel2
description etherchannel to SW5
interface GigabitEthernet1/0/5
switchport access vlan 7
switchport mode access
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
switchport access vlan 2
interface GigabitEthernet1/0/10
description RemusSQL_Lan
switchport access vlan 17
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
switchport access vlan 6
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
description Romulus_Lan
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
description Cleito_ILO
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
description From Firewall
interface GigabitEthernet1/0/24
description Trunk to Swich 2
channel-group 1 mode active
interface Vlan1
ip address 172.18.6.14 255.255.255.0
no ip route-cache
interface Vlan6
ip address 192.168.216.2 255.255.255.0
interface Vlan7
ip address 192.168.217.2 255.255.255.0
interface Vlan17
ip address 192.168.215.2 255.255.255.0
ip default-gateway 172.18.6.16
ip classless
ip http server
control-plane
line con 0
end
SWITCH5
SW5#sh run
Current configuration : 5534 bytes
version 12.2
no service pad
service timestamps log datetime localtime
hostname SW5
enable secret xxxxxxxxxxxx
no aaa new-model
clock timezone UTC -6
ip subnet-zero
ip routing
no file verify auto
interface Port-channel4
description EMC_Standby cge1
channel-group 2 mode active
description EMC_Standby cge2
description EMC_Data1 cge0 - Active (Server_2)
spanning-tree portfast
description EMC_Data1 cge0 - Active (Server_3)
description EMC_Data1 RemusSQL (Teamed)
description EMC_Cifs
description EMC_Backup Cleito (to be configured)
description Cleito
description Cleito
channel-group 4 mode active
description EMC Management Port
description Despina
interface Vlan1
ip address 172.18.6.16 255.255.255.0
interface Vlan2
ip address 192.168.218.1 255.255.255.0
interface Vlan3
ip address 192.168.219.1 255.255.255.0
interface Vlan4
ip address 192.168.220.1 255.255.255.0
interface Vlan5
ip address 192.168.221.1 255.255.255.0
interface Vlan6
ip address 192.168.216.1 255.255.255.0
interface Vlan7
ip address 192.168.217.1 255.255.255.0
interface Vlan12
ip address 192.168.224.1 255.255.255.0
interface Vlan15
ip address 192.168.227.1 255.255.255.0
interface Vlan17
ip address 192.168.215.1 255.255.255.0
interface Vlan900
ip address 10.11.6.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.6.1
ip route 10.0.0.0 255.0.0.0 172.18.6.2
ip route 172.16.0.0 255.248.0.0 172.18.6.2
ip route 192.168.0.0 255.255.0.0 172.18.6.2
ip http server
ip access-list extended wireless
deny   ip 10.11.6.0 0.0.0.255 172.18.0.0 0.0.255.255
deny   ip 10.11.6.0 0.0.0.255 192.168.0.0 0.0.255.255
permit ip 10.11.6.0 0.0.0.255 any
access-list 5 permit 172.18.120.0 0.0.0.255
control-plane
end
Hi Adam, I forgot to mention Switch models....they are both WS-C3750G-24T
