LAN ports are amber after download config using TFTP
Wernerke01
I'm struggling with download of a config file from a serverlocation to a 3560 switch. I recieved a new switch and configured it manually. Ahtis this succesfull action and tested the config, I uploaded this config using TFTP to a server location. I clreaed the config on this switch ( reset to factory), connected the switch with a LAN port to the network, booted up the switch, connected via console to the switch and downloaded the saved config from server location to the switch using TFTP. All seems to be ok, but when I connect the switch with fiber to the network, Fiber is OK but all LAN ports are AMBER.
speed and duplew set to auto,no shutdown, same problem
anyone some ideas
21 Replies 21
Davy Ad
What type of interface is that port , check that is capable of Fibre optic(Gigaethernet). Also check your fibre as well.It could be the configuration you upload from TFTP Server has different interface as what you have now.Are the switch the same model?
DAK
all ports are fastethernet ports directly connected to PC
Gigabit ports are working fine
Did u tried show interface and analyze the data
GENNDSEFLO20#sh inf fa 0/1 fa 0/1
FastEthernet0/1 is up, line protocol is up (connected)
Hardware is Fast Ethernet, address is 0019.aac4.6c03 (bia 0019.aac4.6c03)
Description: USER - vlan 2 backbone
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:04, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
333 packets input, 65088 bytes, 0 no buffer
Received 333 broadcasts (0 multicast)
0 watchdog, 0 multicast, 0 pause input
376 packets output, 35344 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Werner,
Have you created the layer 2 VLAN on the switch?
switch#conf t
switch(config)#vlan 2
HTH,
Mark
interface FastEthernet0/41
description USER - vlan 2 backbone
switchport access vlan 2
no snmp trap link-status
no cdp enable
spanning-tree portfast
interface GigabitEthernet0/1
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
udld port
spanning-tree vlan 1-3 cost 5
interface Vlan1
description NMS default VLAN
ip address 192.168.38.21 255.255.255.192
no ip route-cache
this config I entered first manually and this works.
Only when I install the config using TFTP I have the problem
Add the following to your TFTP config.
vlan 2
name User VLAN
If this does not help, please post your TFTP config.
Mark
As suggested by Mark check have you created vlan2 before you assign port to that vlan.
Light is amber when STP is blocking . Can you check is spanning tree is blocking ur ports
conf t VLAN 2
int vlan 2
description user - vlan 2 backbone
No ip address
same problem
sh spanning-tree blockedports
no ports blocked
can you tell me what need to be configured for TFTP? Is this realy needed as i can download the complete config from tftp server.
just asking as I'm not so familar with this.
There shouldn't be anything special to configure the switch from TFTP. Are you able to post the TFTP config?
Mark
do you mean the configuration that will be downloaded by TFTP
for the moment when entering after reboot switch
conf t
Vlan 2
no shutdown
it works
Yes the configuration downloaded by TFTP. If that is the solution that works for you just add "no shutdown" under VLAN 2 on your TFTP configuration.
I entered the command no shutdown for vlan 2
and ports are working
did then a copy run to start
uploaded config to server with TFTP
Copy system:/running-config tftp://........B
Copy startup-config tftp://........S
downloaded the running config using TFTP to the switch same problem after manually no shutdown" under VLAN 2 it's working
reseted the switch
downloaded the startup config using TFTP to the switch same problem after manually "no shutdown" under VLAN 2 it's working
Try this config. I added vlan 2 and added a no shutdown to the VLAN interface.
