07-02-2018 11:06 AM - edited 03-08-2019 03:32 PM
Hi all,
I am having this confusion for quite sometime now.
I have a simple setup with a FW connected to L2 switch then to an ISP router. My ISP link has a 4Mb capped on the egress.
[My FW] <-1Gb link-> [p0 L2 Switch p1] <-1Gb link-> [ISP Router] <- 4Mb link ->
Doing a SNMP bandwidth capture on switch2's port1 (facing ISP router), it is reflecting a 4Mb maximum bandwidth usage.
But what I don't understand is this as below ->
You might say, the ISP maximum bandwidth is capped at 4Mb, thus the bandwidth capture is correct.
But the link between the switch and the router is a 1Gb link and there isn't any policing/shaping down at the ingress port at the Router.
The FW doesn't know the Router has a 4Mb capped, it will just send all the traffic it needs over to the Router at full bandwidth of 1Gbps.
So why isn't the bandwidth capture reflect at port1 on the LAN side showing more then 4Mbps ?
p.s. the bandwidth graph show a maxout flat line of 4Mbps usage, so the Firewall is definitely sending more then 4Mbps, but why isn't it reflecting in the graph since the capture is on the LAN side ?
Solved! Go to Solution.
07-05-2018 09:44 AM - edited 07-05-2018 09:45 AM
Hi all,
Just want to share if anyone encounter the same doubt as me.
The reason is simple, because I am using TCP traffic and TCP will somehow "shape"/"throttle" into the maximum bandwidth at the WAN side.
If I am sending UDP traffic, the LAN side bandwidth capture can go as high as the line rate
Noob
07-05-2018 11:30 AM
07-02-2018 11:30 AM
What is management software are you using to see the bandwidth usage?
07-02-2018 06:03 PM - edited 07-02-2018 06:35 PM
Hi Reza.
Thanks for your reply. I tried a couple of tools like whatsup / zabbix but in fact this is happening to all my ISP links. The LAN side is capable of 1Gbps transfer but the bandwidth usage capture is reflecting the ISP's capped limit.
My confusion is our FW on the LAN side has no idea that the Router's Egress is capped at which limit and thus should be sending traffic towards the Router at full 1Gbps.
I checked the Router LAN port and there is no ingress policing/shaping.
So why is the capture at Switchp1 reflecting 4Mbps instead of a full 1Gbps ?
[FW] <--1Gbps--> [Switch p1] <--1Gbps--> [lan ROUTER wan] <--4Mbps cap-->
Noob
07-02-2018 12:03 PM
As you mentioned that there is one Gigabits link till to ISP router and there is no policy etc so all traffic maximum 1gbps (may your firewall not support) forwarded to ISP router. Now ISP router having 4Mbps capping so traffic may put in Queue ( as per QoS configuration) or in the buffer or out of buffer traffic may drop.
So why isn't the bandwidth capture reflect at port1 on the LAN side showing more than 4Mbps?
Ans: This is becuase capping is applied on the wan interface and router is following the traffic follow rules.
Deepak Kumar
07-02-2018 06:11 PM - edited 07-02-2018 06:36 PM
Hi Deepak,
Thanks for your reply. But as you mentioned, the WAN interface of the router is capped but the LAN interface connected to the FW is not capped or policed and it is a full 1Gb link.
The FW has no knowledge that there a capped on the router's WAN interface and if the router is dropping its packet. So the FW should be sending traffic towards the Router at full 1 Gbps right ?
But somehow the bandwidth capture on switch port1 connected to the ISP router's LAN interface is reflecting the capped limit of 4Mbps instead of 1Gbps. ( shouldn't it be showing 1Gbps instead ?)
Any idea why ?
Noob
Hi all,
Noob
07-05-2018 11:30 AM
