Laptop direct connect to 3750G and ping SVI
vovochka83
I tried to ping the SVI ip address by direct connected to the 3750G switch access port vlan 10,
Switch:
interface vlan 10
192.168.10.2
standby 0 ip 192.168.10.1
standby 0 priority 115
standby 0 preempt
My laptop:
192.168.10.100
So i ping to 192.168.10.1, and my ping test result is around <15ms, and the switch resources are low as well, i am not sure whether it is normal?
5 Replies 5
Did you check with another laptop to compare?
Yes, almost same result...
I tried to use a spare switch with same model and same IOS version, without connected to any other devices, and then create SVI and plug my laptop into this switch then ping, still the ping result is around 12-15ms. Am i suppose to get <5ms in this scenario?
How much is the CPU of this switch? Is the HULC LED process is high?
Madhu
is not high as below:
hostname#sh processes cpu sorted
CPU utilization for five seconds: 15%/1%; one minute: 17%; five minutes: 16%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
 226   989199448 486960646       2031  4.95%  5.03%  5.04%   0 Spanning Tree
  72    75622700 842671225         89  0.79%  0.41%  0.41%   0 Fifo Error Detec
 110   144545652  16791173       8608  0.63%  0.77%  0.79%   0 hpm counter proc
   9    33504722  65302827        513  0.63%  0.34%  0.32%   0 ARP Input
 150    73761412 613874853        120  0.47%  0.41%  0.39%   0 Hulc LED Process
