Large numbers of Total output drops
mcguirebob
We have 2 switches, each with 3 Gig interfaces that are used as the VLAN for data replication between 3 nodes of an HA SAN (with gig nics).  These ports are showing a large number of Total output drops in the show interface output.  What things can I try to narrow down where the issues are coming from?  Here's is the output of one of the interfaces:
SWSAN1#show interfaces GigabitEthernet 0/2
GigabitEthernet0/2 is up, line  protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0014.a80e.2382 (bia 0014.a80e.2382)
  Description: SAN1_BPlane
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10  usec,
     reliability 255/255, txload 2/255, rxload 2/255
  Encapsulation ARPA, loopback not  set
  Keepalive set  (10 sec)
  Full-duplex, 1000Mb/s, media type is  10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  ARP type: ARPA, ARP Timeout  04:00:00
  Last input never,  output 00:00:00, output hang never
  Last clearing of "show interface"  counters never
  Input queue: 0/75/0/0  (size/max/drops/flushes); Total output drops:  3871100
  Queueing strategy: fifo
  Output queue: 0/40  (size/max)
  5 minute input rate 10183000 bits/sec,  1448 packets/sec
  5 minute output rate 11561000 bits/sec,  1510 packets/sec
     1493229684 packets input,  1329967163222 bytes, 0 no buffer
     Received 7240 broadcasts (3  multicasts)
     0 runts, 0 giants, 0  throttles
     0 watchdog, 3 multicast, 0 pause  input
     0 input packets with dribble condition  detected
     1638884964 packets output,  1837773160862 bytes, 0 underruns
     0 output errors, 0 collisions, 0  interface resets
     0 lost carrier, 0 no carrier, 0 PAUSE  output
     0 output buffer failures, 0 output  buffers swapped out
Thanks in advance
8 Replies 8
spremkumar
Level 9
Level 9
Are you seeing continous increments within the output drop counter? can you check clearint the counters once? also cna you paste the config of this interface? are you seeing anything in the logs with respect to  this interface? drops occurs mainly due to insufficient queue size to hold the data.
regds
Yes, on the one interface that this system is using out of the 6, the drops continue to occur after clearing the counters, and again, this is the only interface that is showing anything on the 5 minute input and output rates.
interface config:
interface GigabitEthernet0/2
description SAN1_BPlane
switchport access vlan 100
switchport mode access
flowcontrol receive on
spanning-tree portfast
SWSAN2#show interfaces gigabitEthernet 0/2
  Hardware is Gigabit Ethernet, address is 0014.a82e.aa02 (bia 0014.a82e.aa02)
  Description: FICPASAN1_BPlane
     reliability 255/255, txload 4/255, rxload 6/255
  input flow-control is on, output flow-control is unsupported
  Last input never, output 00:00:01, output hang never
  Last clearing of "show interface" counters 00:08:35
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1594
  5 minute input rate 26124000 bits/sec, 2965 packets/sec
  5 minute output rate 16630000 bits/sec, 2566 packets/sec
     1953356 packets input, 2072245740 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 watchdog, 0 multicast, 0 pause input
     1780461 packets output, 1551855955 bytes, 0 underruns
mcguirebob
Now a couple of the other interfaces are starting to see some traffic, and the drops are incrementing on those also.  The configuration for all of the interfaces is the same:
SWSAN2#show interfaces gigabitEthernet 0/4
GigabitEthernet0/4 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0014.a82e.aa04 (bia 0014.a82e.aa04)
  Description: SAN2_BPlane
     reliability 255/255, txload 3/255, rxload 2/255
  Last clearing of "show interface" counters 00:16:08
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 74
  5 minute input rate 11233000 bits/sec, 1632 packets/sec
  5 minute output rate 14599000 bits/sec, 1765 packets/sec
     1715069 packets input, 1361564336 bytes, 0 no buffer
     1976729 packets output, 2143226538 bytes, 0 underruns
To be able to troubleshoot output drops, i would require the following outputs
if it is a modular switch, i would require the following outputs, if its not a module switch, i would need show version and output #2 and 3
1. show mod
2. show int | inc line | drops
3. show int | inc line | rate
Capture output 2 and 3 twice in successsion
What i want to see is the rate at which the drops are incrementing
SWSAN2#show version
Cisco IOS Software, C3560 Software (C3560-IPBASEK9-M), Version 12.2(53)SE2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 21-Apr-10 05:33 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02B00000
ROM: Bootstrap program is C3560 boot loader
BOOTLDR: C3560 Boot Loader (C3560-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
SWSAN2 uptime is 22 weeks, 1 day, 9 hours, 36 minutes
System restarted at 06:31:06 EDT Tue Aug 10 2010
System image file is "flash:c3560-ipbasek9-mz.122-53.SE2/c3560-ipbasek9-mz.122-53.SE2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3560G-24TS (PowerPC405) processor (revision C0) with 131072K bytes of memory.
Processor board ID FOC0924U2RA
Last reset from power-on
2 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:14:A8:2E:AA:00
Motherboard assembly number     : 73-9708-04
Power supply part number        : 341-0098-01
Motherboard serial number       : FOC09245D0J
Power supply serial number      : DCA09210JX8
Model revision number           : C0
Motherboard revision number     : A0
Model number                    : WS-C3560G-24TS-S
System serial number            : FOC0924U2RA
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT09220WNP
Top Assembly Part Number        : 800-25864-02
Top Assembly Revision Number    : A0
Version ID                      : 02
CLEI Code Number                : CNMW200ARB
Hardware Board Revision Number  : 0x05
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3560G-24TS     12.2(53)SE2           C3560-IPBASEK9-M
Configuration register is 0xF
FICPASWSAN2#show int | inc line | drops
Vlan1 is up, line protocol is up
Vlan102 is up, line protocol is up
GigabitEthernet0/1 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1786
GigabitEthernet0/3 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 1046
GigabitEthernet0/5 is up, line protocol is up (connected)
GigabitEthernet0/6 is up, line protocol is up (connected)
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 990
GigabitEthernet0/7 is up, line protocol is up (connected)
GigabitEthernet0/8 is down, line protocol is down (notconnect)
GigabitEthernet0/9 is up, line protocol is up (connected)
GigabitEthernet0/10 is down, line protocol is down (notconnect)
GigabitEthernet0/11 is down, line protocol is down (notconnect)
GigabitEthernet0/12 is down, line protocol is down (notconnect)
GigabitEthernet0/13 is up, line protocol is up (connected)
GigabitEthernet0/14 is up, line protocol is up (connected)
GigabitEthernet0/15 is up, line protocol is up (connected)
GigabitEthernet0/16 is up, line protocol is up (connected)
GigabitEthernet0/17 is up, line protocol is up (connected)
GigabitEthernet0/18 is down, line protocol is down (notconnect)
GigabitEthernet0/19 is up, line protocol is up (connected)
GigabitEthernet0/20 is down, line protocol is down (notconnect)
GigabitEthernet0/21 is up, line protocol is up (connected)
GigabitEthernet0/22 is up, line protocol is up (connected)
GigabitEthernet0/23 is up, line protocol is up (connected)
GigabitEthernet0/24 is down, line protocol is down (notconnect)
GigabitEthernet0/25 is down, line protocol is down (notconnect)
GigabitEthernet0/26 is down, line protocol is down (notconnect)
GigabitEthernet0/27 is down, line protocol is down (notconnect)
GigabitEthernet0/28 is down, line protocol is down (notconnect)
Port-channel2 is up, line protocol is up (connected)
FICPASWSAN2#show int | inc line | rate
  5 minute input rate 3000 bits/sec, 5 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
  5 minute input rate 20399000 bits/sec, 2129 packets/sec
  5 minute output rate 7659000 bits/sec, 1595 packets/sec
  5 minute input rate 4262000 bits/sec, 1002 packets/sec
  5 minute output rate 13334000 bits/sec, 1386 packets/sec
  5 minute input rate 138000 bits/sec, 3 packets/sec
  5 minute output rate 16000 bits/sec, 8 packets/sec
  5 minute input rate 8016000 bits/sec, 1200 packets/sec
  5 minute output rate 11662000 bits/sec, 1352 packets/sec
  5 minute output rate 4000 bits/sec, 5 packets/sec
  5 minute input rate 1422000 bits/sec, 119 packets/sec
  5 minute output rate 112000 bits/sec, 45 packets/sec
  5 minute input rate 176000 bits/sec, 6 packets/sec
  5 minute output rate 255000 bits/sec, 8 packets/sec
  5 minute input rate 417000 bits/sec, 32 packets/sec
  5 minute output rate 3000 bits/sec, 4 packets/sec
  5 minute input rate 544000 bits/sec, 117 packets/sec
  5 minute output rate 2968000 bits/sec, 260 packets/sec
  5 minute input rate 24000 bits/sec, 5 packets/sec
  5 minute output rate 182000 bits/sec, 10 packets/sec
  5 minute input rate 78000 bits/sec, 45 packets/sec
  5 minute output rate 1650000 bits/sec, 138 packets/sec
  5 minute input rate 192000 bits/sec, 12 packets/sec
  5 minute output rate 285000 bits/sec, 96 packets/sec
  5 minute input rate 2603000 bits/sec, 223 packets/sec
  5 minute output rate 137000 bits/sec, 4 packets/sec
  5 minute input rate 2820000 bits/sec, 260 packets/sec
  5 minute output rate 437000 bits/sec, 115 packets/sec
  5 minute input rate 1000 bits/sec, 2 packets/sec
  5 minute input rate 3000 bits/sec, 1 packets/sec
  5 minute output rate 3000 bits/sec, 1 packets/sec
  5 minute input rate 19853000 bits/sec, 2053 packets/sec
  5 minute output rate 7125000 bits/sec, 1516 packets/sec
  5 minute input rate 4083000 bits/sec, 946 packets/sec
  5 minute output rate 12587000 bits/sec, 1307 packets/sec
  5 minute input rate 265000 bits/sec, 19 packets/sec
  5 minute output rate 24000 bits/sec, 18 packets/sec
  5 minute input rate 7448000 bits/sec, 1148 packets/sec
  5 minute output rate 11658000 bits/sec, 1325 packets/sec
  5 minute output rate 2000 bits/sec, 2 packets/sec
  5 minute input rate 1276000 bits/sec, 105 packets/sec
  5 minute output rate 101000 bits/sec, 37 packets/sec
  5 minute input rate 803000 bits/sec, 62 packets/sec
  5 minute output rate 219000 bits/sec, 12 packets/sec
  5 minute input rate 376000 bits/sec, 26 packets/sec
  5 minute input rate 478000 bits/sec, 102 packets/sec
  5 minute output rate 3088000 bits/sec, 267 packets/sec
  5 minute input rate 23000 bits/sec, 8 packets/sec
  5 minute output rate 174000 bits/sec, 13 packets/sec
  5 minute input rate 68000 bits/sec, 40 packets/sec
  5 minute output rate 1477000 bits/sec, 123 packets/sec
  5 minute input rate 161000 bits/sec, 21 packets/sec
  5 minute output rate 276000 bits/sec, 79 packets/sec
  5 minute input rate 2130000 bits/sec, 180 packets/sec
  5 minute output rate 238000 bits/sec, 19 packets/sec
  5 minute input rate 2313000 bits/sec, 223 packets/sec
  5 minute output rate 532000 bits/sec, 109 packets/sec
The output drops are the number of packets dropped because the output queue is full. A
common cause of this might be traffic from a high bandwidth link being switched to a lower
bandwidth link or traffic from multiple inbound links being switched to a single outbound
link. For example, if a large amount of bursty traffic comes in on a gigabit interface and
is switched out to a 100Mbps interface, this might cause output drops to increment on the
100Mbps interface. This is because the output queue on that interface is overwhelmed by
the excess traffic due to the speed mismatch between the inbound and outbound bandwidths.
What kind of traffic are you running?
Do you have havey multicast traffic running across these links?
Please change the "load-interval 30 " to minimal under the switch interfaces to get more granular input and
output rate from the interfaces.
What IOS version are you running and which switch?
It might also be a bug but need to check the details just in case.
Cheers,
-amit singh
Yes, however, both the interface and the nic is 1000Mbit, and
the setup is pretty simple - 2 3560 switches, 3 ports on each (in question), all on the same VLAN, 1 port on each switch connects to one NIC on each of the 3 SAN nodes
The interfaces are showing less than 5% utilization.
Not sure of the traffic except that it's replication traffic from CentOS using GPFS filesystems.
show version is posted above.
can you explain what you mean about changing the load-interval 30?
Gurpreet Kochar
The output drops are not incrementing rapidly, it gives me an impression that they are being caused by bursty traffic
The interface monitors the average traffic rate over the interval of 5 minutes.
What if the burst occures during the few seconds of those 5 minutes over which the traffic rate was measured, the interface would never be able to show you the exact details
The traffic may peak for lets say 3-5 seconds and exceed the threshold of the inteface and at that moment the traffic is dropped.
By reducing the load-interval to 30seconds you are monitoring the traffic rate on the interface over an interval of 30secs rather than 5 minutes.
This would give you a better picture but not a precise view.
