Late Collissions - Ethernet 0 Interface 1721 Router
Anup Sasikumar
Hello ,
I have been observing high amount of Late Collisions on Ethernet 0 interface for a Cisco 1721 Router (LOL EOL for sure )
The internet line terminates on the interface
#sh int e0
6640 output errors, 5677 collisions, 0 interface resets
0 babbles, 6454 late collision, 10467 deferred
#sh controllers | i single
4304 single collisions, 1373 multiple collisions
For LAN Access ,the router has GRE IPSec Tunnels which forms EIGRP Neighborship with Remote end Router
Due to this issue , lately the GRE IPsec Tunnels flaps causing EIGRP Neighborship to get disrupted often resulting in connectivity loss
As late collssions can mostly be caused by Duplex mismatch , I checked the duplex settings and that seems to be fine
(https://supportforums.cisco.com/thread/9246)
1. The LAN has around 200 nodes connected via Fa0 intreface , Can the Speed mismatch ( 10Mbps and 100 Mbps ) cause bottle necks and be the reason for Late collissions ?
2. Are Late collissions bad ?
3. What are the options ahead of me to try and resolve this issue ?
Please Help !
Anup
Anup
Leo Laohoo
No.  Speed mismatch gives you CRC or FCS.  Collisions, as a whole, means you're interface is set up for HALF duplex.
Post the complete output to the command "sh interface ".
Ethernet0?  I believe this interface can only negotiate HALF duplex.
Leo Laohoo
Hi Leo ,
It 's Half Duplex itself !
Sorry I checked the Fa0 port and found it to be Full Duplex
For E0
Ethernet0 is up, line protocol is up
  Hardware is PQUICC Ethernet, address is 000d.28db.6d26 (bia 000d.28db.6d26)
  Description: == Public IP ==
  Internet address is 1.2.3.4/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Half-duplex, 10BaseT
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/351/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 3000 bits/sec, 3 packets/sec
  5 minute output rate 3000 bits/sec, 3 packets/sec
     3962930 packets input, 1547443857 bytes, 640 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     6677 input errors, 0 CRC, 0 frame, 5 overrun, 6666 ignored
     5588762 packets output, 1453864156 bytes, 0 underruns
     6666 output errors, 5697 collisions, 0 interface resets
     0 babbles, 6480 late collision, 10494 deferred
     186 lost carrier, 0 no carrier
Anup
Anup
