Bookmark
Subscribe
3628
Latency of Cisco Nexus 93180YC-FX
ranjit123
Level 3
Level 3
ear All,
I wanted to check latency of Nexus 93180YC-FX as per data sheet it says latency is 1 microsecond.
Our requirement is to reduce to the same to nano second is there any license available for the same?
where we can install the license in the box and reduce the latency..
Ranjit
marce1000
 - Licensing and hardware performance are unrelated.
   M.
You should be using 3ks and 6ks for low latency , 9ks are store and forward switches if you want low latency for likes of super sensitive apps or stocks use cut through switches , nx 6ks and 3ks
i use 91380s and 93240s ,stable switches but not specifically LL
3500s NX
Lowest latency in the industry
https://www.cisco.com/c/en/us/products/switches/nexus-3000-series-switches/index.html#~stickynav=1
anthonykahwati
I know this thread is a couple of years old now, but is there anything more specific on the latency of the 93180YC-FX3?
I've seen the data sheet that just specifies sub milli-second but looking for more detail like port to port, actual ns/ms numbers, etc.
Thanks in advance
