07-13-2017 08:08 AM - edited 03-08-2019 11:18 AM
I have the following scenario (refer to the attached 'setup')
I am at HQ and when a undertake a Traceroute to each sever:
Could the Latency be caused by issues with the Switch Stack setup?
Thanks.
07-13-2017 08:19 AM
In the traceroute to the branch 2 server where does the value increase in the latency is it right between switch ip and server hop
if your local on the network not coming from HQ do you see the same result
no issues on the server switch port , crcs , inputs or collisions etc
I wouldn't have thought it was the stack itself causing it , usually if something's up with the stack you wont just see 1 device effected
07-13-2017 08:25 AM
In the traceroute, the latency increases at the Router Virtual IP address
07-13-2017 08:41 AM
But server 1 would also pass over this vip address too yes in path , the 2 routers are in redundancy form like hsrp is that correct , both I presume take the exact same path until they hit the server ip or is it different
