Bookmark
Subscribe
13240
Latest firmware for WS-C3560-8PC-S
Hi.
I would like to know if it is possible to acquire the latest firmware for this switch from somewhere?
Leo Laohoo
I am very sure the WS-C3560-8PC-S is a "regular" 3560 model and the final stable release is 12.2(55)SE train, which can be found HERE.
NOTE:
Read the Release Notes very carefully.
Download the TAR file and use the following command to safely unpack the firmware into the switch:
archive download-sw tftp://<TFTP_IP_ADDRESS>/IOS_filename.tar
8 Replies 8
marce1000
 https://software.cisco.com/download/home/283915797/type/280805680/release/15.2.2E10
 M.
Thanks. Does this version work for the 3560-non C model as well?
No, the 3560-C has a C in the name but the regular 3560 does not.
c3560c405-universalk9-mz.152-2.E10.bin
c3560-ipbasek9-mz.122-55.SE12.bin
So I can assume that this version (c3560-ipbasek9-mz.122-55.SE12.bin - listed under 24/48 port models) is universal and should work with 8PC model?
No, c3560-ipbasek9-mz.122-55.SE12.bin only works on 24 or 48 port regular 3560s and not the 8PC model.
Leo Laohoo
NOTE:
Ok. Release notes were Not very clear:
  • Cisco IOS Release 12.2(55)SE runs on all Catalyst 3750, 3560, 2975, 2960-S, and 2960 switches and on Cisco EtherSwitch service modules.
  • Cisco IOS Release 12.2(55)SE1 runs on all Catalyst 3750, 3560, 2960-S, and 2960 switches and on Cisco EtherSwitch service modules.
  • Cisco IOS Release 12.2(55)SE2 runs on Catalyst 2960-S switches only.
...but since that v12.2(55)SE1 was not available for download (I could only download v12.2.55-SE12) and Leo was certain that this version would work, I decided to try it. The switch has been upgraded successfully!
