i will use a switching module in 3945 router instead of 2960 switch
existing ios version(old-switch) is 12.2(44)SE6
new ios version(new-sm module) is 12.2(55)SE7
existing ios version mab do work fine, but new ios version mab don't work
--- existing configuration ---
aaa new-model
aaa authentication
login default local
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa session-id common
dot1x system-auth-control
interface xx
switchport access vlan 10
switchport mode access
dot1x mac-auth-bypass
dot1x pae authenticator
dot1x port-control auto
dot1x violation-mode protect
spanning-tree portfast
--- new configuration ---
aaa new-model
aaa authentication login default local
interface xx
authentication port-control auto
mab
as ios version upgrade, some of the configuration has been changed and
mac authentication bypass is not working, so please tell me why these
problem occur
