Nexus5020 and voice vlan
Rosa Ladeira
I am configuring voice vlan on a Nexus5020 version 5.2(1)N1(8b).
I am getting the following error message:
nx5020-wc0(config)# interface Ethernet1/15
nx5020-wc0(config-if)#   description Guarita
nx5020-wc0(config-if)#   switchport access vlan 2
nx5020-wc0(config-if)#   switchport voice vlan 112
ERROR: Configuration command not supported
nx5020-wc0# sh vlan brief
VLAN Name                             Status    Ports
1    default                          active    Po75, Eth1/1, Eth1/2, Eth1/6
                                                Eth1/7, Eth1/8, Eth1/12, Eth1/18
                                                Eth1/19, Eth1/20, Eth1/21
2    administrativa                   active    Po25, Po75, Eth1/1, Eth1/2
                                                Eth1/4, Eth1/5, Eth1/9, Eth1/10
                                                Eth1/15
3    sbm                              active    Po75, Eth1/1, Eth1/2, Eth1/4
4    pesquisadores                    active    Po25, Po75, Eth1/1, Eth1/2
110  servidores-internos              active    Po25, Po75, Eth1/1, Eth1/2
                                                Eth1/9, Eth1/10
111  wifi-voip                        active    Po75, Eth1/1, Eth1/2
112  telefones-voip                   active    Po75, Eth1/1, Eth1/2, Eth1/4
                                                Eth1/5
Reza Sharifi
Hi Rosa,
The Nexus series switches do not support POE/Voice.
And why are there enabled voice commands on version 5.2(1)N1(8b). ?
Not sure.  These switches are not POE switches.  They are designed for data center and not campus.
