Layer 2 & 3 switch 3550
jmaurer1205
Level 3
Level 3
I'm configuring VLAN's on a Cisco 3550 & 2960. The 3550 is a layer 2 & 3 switch. I've configured the "router on a stick" config before but this is the first time on a layer 2 & 3 switch. Then trunking to 2960 thru gi ports.
How would I connect the VLAN's together to be routed? Do I put the IP on the VLAN or do I configure subinterfaces on the router port? And if I put the IP on the VLAN can I apply acl to it like an interface?
I'm thinking that you wouldn't create sub-int, you would need to connect a cable and trunk it.
Collin Clark
The 3550 will have SVI's- Switched Virtual Interfaces. What that means is each VLAN can have a layer 3 address.
switch(config)# interface vlan 5
switch(config-int)# ip add 10.10.5.254 255.255.255.0
switch(config)# interface vlan 6
switch(config-int)# ip add 10.10.6.254 255.255.255.0
You'll need to enable ip routing-
switch(config)# ip routing
Now hosts between the VLANs can communicate. Finally to add the 2960 into the mix, you will want to create a trunk between the switches. No sub-interfaces needed and you can apply ACLs inbound and outbound.
HTH and please rate.
vanguardro
Community Member
hello,
one method to configure your network, is to have all switches in same vtp domain,
for example:
sw 3560 can be your server for vtp domain
vtp mode server
vtp domain MyNetwork
and on all of your 2960 switches can be clients on this VTP domain
vtp mode client
interconnection between switches can be done with trunk command:
in gi 0/1
sw tr en dot
sw mo tr
and now we can create some vlan in vlan databases on our server
3560#conf t
vlan 10
name users10
vlan 11
name user11
vlan 30
name servers
if all interconnection is done proprely, vlan information will be propagated to all your clients (aka access-switches in your vtp domain)
now we will work on our vlan routing problem
on our L3 switch 3560 we will assign ip address to interface vlan:
interface vlan 10
description Interface Vlan10
ip address 172.16.10.0 255.255.255.0
no shut
int vlan 11
desc Interface Vlan11
ip address 172.16.11.0 255.255.255.0
no shut
int vlan 30
desc interface servers
ip address 172.16.30.0 255.255.255.0
no shut
ip routing
doing this, routing will be done in 3560 and 2960 will be used as access-switches
also you can create some acl and apply this acl to int vlan
int vlan 10
ip access-gr 10 in
best regards,
vanguardro
