Layer 2 Etherchannel between ISR4431 and 3750 Switch Stack
dmadaffari1
I am seeking the best way to create an L2 Etherchannel between ISR 4431 and 3750 stack.  ISR4431 router ports do not support L2 and NIM-ES2-4 module does not support Etherchannel (cannot believe this).  Need to replace current 3954E w/ ESM installed with ISR4431.
Current topology: ISR3945E >> 16 Port ESM >> Etherchannel to 3750 Stack
Is there a way?
balaji.bandi
that feature not supported
have a look L3 PO if that is your requirement.
https://www.cisco.com/c/dam/en/us/products/collateral/routers/3800-series-integrated-services-routers-isr/prod_white_paper0900aecd806f698a.pdf
BB
BB
a.alekseev
Level 7
Level 7
you can use L3 Etherchannel
dmadaffari1
I am awaiting one more product development resource to get back to me and verify that this module is not capable of L2 EtherChannel.  If not, then I will have to redesign.  Seems this is a fairly fundamental feature and other larger NIMs for 4000 Series ISRs do support it.
Thanks for feedback.
