06-05-2025 12:07 PM - edited 06-05-2025 12:11 PM
Hello all, hoping to get some help in one of my configurations. So my topology is we have a inside network PLC on a 192.168.1.50 address. This address is local only so that the PLC can communicate with its other accessory devices on the 192.168.1.x network. All the inside devices use 192.168.1.2 as a gateway to the PLC (the 192.168.1.50). We've set up a VLAN 999 on all of our IE Switches access ports so that the devices could talk across switches back to the PLC.
The PLC needs to be able to reach our outside network. 10.49.152.x (VLAN 152) to be able to communicate. So I setup a l2nat and translated the 192.168.1.50 address to 10.48.152.6 address so we could see it now.
The problem is now that I've setup this translation, I'm assuming because I've changed the access port to vlan 152 on the PLC Interface. The PLC is visible to us now on the outside network, but all of the accessory devices can no longer see it.
Here is my configuration below: My question is what am I missing so that this PLC can be visible to both its private network and its outside public? If I change the PLC interface to 999 again. I can no longer see the PLC outside address, but if i change it to 152, I can see it but the accessory devices can't. Can anyone help?
L2 NAT Instance Config:
l2nat instance PLC_NAT
permit all
fixup all
outside from host 10.49.152.1 to 192.168.1.2 gateway
outside from host 10.49.152.6 to 192.168.1.50
inside from host 192.168.1.50 to 10.49.152.6
Uplink Interface Config:
switchport mode trunk
l2nat PLC_NAT 152
storm-control broadcast level 3.00 1.00
macro description cisco-ethernetip
PLC Interface Config:
switchport access vlan 152
switchport mode access
Accessory Devices Interface Configs:
switchport access vlan 999
06-07-2025 07:29 AM - edited 06-07-2025 07:41 AM
I've not actually worked with L2NAT before,
but reading the doc's
( https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/industrial/software/configuration/guide/b_l2_nat_ie.html
figure 2 and config example)
i think you only need
and put the PLC in vlan999
it is important where the connection is initiated
you may need an additional translation for the outside hosts to the 192.168.1.x subnet for connections initiated from the outside,
but that will NOT be "outside from host 10.49.152.6 to 192.168.1.50" as 10.49.152.6 is the translated address of the PLC!
you need to translate the outside host to an internal address
