layer 2 switch - ip routing
yomal1447
Can anyone help me to advise the model "WS-C2960X-48TS-LL" Supports IP Routing or not?
D.Yomal
2 Accepted Solutions
Mark Malone
No that's a lanlit with LL its pure basic layer 2 only , lanlite cannot be altered
The last letter in the product ID. If the last letter is “-L,” it’s LAN Base. If it’s “-LL,” it’s LAN Lite. If it’s “-I,” it’s IP Lite
For example:
WS-C2960XR-48FPS-I is IP Lite
WS-C2960X-48LPS-L is LAN Base
WS-C2960X-48TS-LL is LAN Lite
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-2960-x-series-switches/qa_c67-728348.html
Julio E. Moisa
The 2960-X model supports static routing only, it does not support routing protocols like EIGRP, OSPF, etc. But LAN lite image (LL) is very limited and it does not support upgrade to other license.  You could analyze the XR model as well.
Please check this link:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960x/software/15-0_2_EX/routing/configuration_guide/b_rt_152ex_2960-x_cg/b_rt_152ex_2960-x_cg_chapter_010.html
Also I highly suggest verify with this tool (select platform and image) The tool said it support static routing (see image):
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/SearchBySoftware.jsp
I suggest verify with a Cisco partner as well.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Mark Malone
For example:
Thank you very much
Thank you very much
Julio E. Moisa
Hope it is useful
