layer 2 switch vlan and sub-interfaces on router ip addresses
John Cheetley
Level 3
Level 3
Hi cisco techs,
Have searched for some knowledge articles on cisco but some aren't conclusive
Does the IP address on layer 2 switch vlans have to match the ip address on teh sub-interfaces on a cisco router for a router on stick scenario please?
Reza Sharifi
If the switch is layer-2 than the only thing you need is an SVI with IP for management only. For all the other vlans the switch does not need any IP.  You just need a trunk on the switch say with vlan 10,20, and 30 and you need a corresponding sub-interface for each on the router with IP. If in this example vlan 10 is for management you need an SVI on the switch with IP address being on the same segment as the router.
11 Replies 11
Reza Sharifi
Thanks for your response Reza.
OH. I placed separate IP address for both data and voice vlan
And used this on the router side.
Placed in nat outside on one fa port connected to default gateway modem/router and ip nat inside on the trunkport side connecting the router to the switch
If you don't mind, I would like to sent you a copy of config. If that's alright.
Sure. Just post "sh run" from the switch and the router, so we can take a look.
Added as requested. Thanks
Hi John;
Your internet modem is connected where? either on L2 switch or directly on Router F0/0. & L2 switch is connected to which port of router?
Thanks & Best regards;
Hi Ahmedshoaib,
Thanks for your reply.
Internet modem connected to fa0/0 cisco router and fa0/1 connects to port 24 on L2 switch via trunk
Hi John;
Then you need to modify the following configuration:
Switch-Configuration:
interface FastEthernet0/24 no switchport access vlan 24
Note: At a given time switchport either access or trunk. In your case it should be trunk port.
CME-Router Configuration:
ip dhcp pool Data_Scope network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 dns-server 8.8.8.8 4.2.2.2 ! ip dhcp pool Voice_Scope network 192.168.2.0 255.255.255.0 default-router 192.168.2.1 dns-server 8.8.8.8 4.2.2.2 option 150 ip 192.168.0.12
no interface FastEthernet0/0.1
no interface FastEthernet0/0.2
interface FastEthernet 0/0
ip nat outside
interface FastEthernet0/1
no ip address
no shutdown
interface FastEthernet0/1.2
description Data vlan 20
encapsulation dot1Q 2
ip nat inside
interface FastEthernet0/1.3
description Voice vlan 30
encapsulation dot1Q 3
ip address 192.168.2.1 255.255.255.0
ip nat inside
no ip route 192.168.0.0 255.255.255.0 192.168.0.1 no ip route 192.168.2.1 255.255.255.255 192.168.0.1
Note: not required the static route for 192.168.0.0 & 192.168.2.0 due to these are local route for router.
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 10 permit 192.168.2.0 0.0.0.255
no ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 10 interface FastEthernet0/0 overload
Thanks ahmedshoaib,
Apologies for not responding earlier.
Will implement tonight and let you know
Hi ahmedshoaib
Thanks for your patience. Am waiting for my telnet to die out as I had "unwittingly" set exec-timeout to a large number for the minutes. Once I can re-establish connection to the router I will update with your suggestions and happily let you know.
Thanks again :)   :)
Hi Ahmedshoaib,
Sorry about not responding yet. Had lots of troubles with telnet. Trying to get your thoughts implemented tonight. Thanks again.
Thanks Reza for your assistance. Have I supplied you with the that information yet ?
