Layer 2 switch vlan interface
cisco8887
Level 2
Level 2
Hi guys,
I have a questions on vlan interfaces which I pretty much know the answer but need assurance,
why can you have multiple vlan interfaces on 2960 switch which is a layer 2 switch ? it can't do any routing so what is the point ?
In old switches you were only allowed to have one vlan interface for management only but I have worked on few 2960 switches that have many interfaces in vlan and I am confused why .
Many thanks
actually certain 2960s do support routing , ip lite images with stub eigrp and one ospf process limited to around 200 routes , pretty suere 2960xrs only come with L3 image , basic static routing etc as well
The Cisco hardware routing architecture delivers extremely high-performance IP routing in the Cisco Catalyst 2960-XR IP-Lite Switches:
• IP unicast routing protocols (Static, Routing Information Protocol Version 1 [RIPv1], and RIPv2, RIPng are supported for small-network routing applications.
• Advanced IP unicast routing protocols (OSPF for Routed Access) are supported for load balancing and constructing scalable LANs. IPv6 routing (OSPFv3) is supported in hardware for maximum performance.
• Equal-cost routing facilitates Layer 3 load balancing and redundancy across the stack.
• Policy-based routing (PBR) allows superior control by facilitating flow redirection regardless of the routing protocol configured.
• Hot Standby Routing Protocol (HSRP) and Virtual Router Redundancy Protocol (VRRP) provides dynamic load balancing and failover for routed links.
• Protocol Independent Multicast (PIM) for IP multicast is supported, including PIM sparse mode (PIM-SM), PIM dense mode (PIM-DM), PIM sparse-dense mode and Source Specific Multicast (SSM).
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising  out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Perhaps because some 2960s support very limited routing.
I can't see ip routing there so I don't think it does.
It does, since IOS Release 12.2(55)SE:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_58_se/configuration/guide/2960scg/swsdm.html
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_58_se/configuration/guide/2960scg/swipstatrout.html
