Layer 2 Switching
girish.patni
Community Member
I am using a switch(3560X) and a router 7606 for the given setup.
I am doing a simple simulation of attcaching a port (on 7606 router)to the switch and testing it with various speed ,duplex setting.
The switch port is in vlan 2 with ip address x.x.x.234 mask 255.255.255.0
and the attached router port has ip address x.x.x.235 mask 255.255.255.0
The problem is:
The connection is establises for duplex full,speed 1000
      but it does not establish for  duplex full,speed 100
                                        and   duplex half,speed 10.
The ports are 10/100/1000 Ethernet ports.
The output from 3560 is:
3560X#sh int gig 0/10
GigabitEthernet0/10 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is 442b.0389.448a (bia 442b.0389.448a)
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Half-duplex, 10Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:35:39, output 00:35:09, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
3560X#sh run int gig 0/10
Current configuration : 129 bytes
interface GigabitEthernet0/10
switchport access vlan 2
switchport mode access
speed 10
duplex half
end
GigabitEthernet0/10 is up, line protocol is up (connected)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  Last input 00:00:03, output 00:00:01, output hang never
Current configuration : 131 bytes
speed 1000
duplex full
end
And Output from the 7606 link is :
7606-A#sh run int gig 2/10
interface GigabitEthernet2/10
ip address 192.168.0.235 255.255.255.0
speed 10
duplex half
end
7606-A#sh int gig 2/10
GigabitEthernet2/10 is down, line protocol is down (notconnect)
  Hardware is C6k 1000Mb 802.3, address is 0011.bbb1.a140 (bia 0011.bbb1.a140)
  Internet address is 192.168.0.235/24
  MTU 1500 bytes, BW 10000 Kbit, DLY 10 usec,
     reliability 255/255, txload 0/255, rxload 0/255
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input 00:25:11, output 00:25:10, output hang never
  Input queue: 0/75/59/0 (size/max/drops/flushes); Total output drops: 0
  L2 Switched: ucast: 1619 pkt, 103616 bytes - mcast: 4238 pkt, 311393 bytes
  L3 in Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes mcast
  L3 out Switched: ucast: 0 pkt, 0 bytes mcast: 0 pkt, 0 bytes
Current configuration : 102 bytes
speed 1000
duplex full
end
GigabitEthernet2/10 is up, line protocol is up (connected)
  Clock mode is auto
  Last input 00:00:00, output 00:00:37, output hang never
  5 minute input rate 1000 bits/sec, 1 packets/sec
  L2 Switched: ucast: 1656 pkt, 105984 bytes - mcast: 4679 pkt, 342779 bytes
Girish
glen.grant
  Thats because you are not using a crossover cable most likely .  If you are using a straight thru cable the link will only come up if the port settings are set for auto/auto  because the mdix feature will only work if the ports are auto.    Generally leave gig ports as auto . I bet if you change the 3560 side to auto the link will come up .  You can set the 3560 side as auto and restrict the speed to 100 if you want .  USe the "speed auto 100"  or speed auto 10"  commands.
glen.grant
