Layer 3 etherchannel subinterface & Broadcast domain
prasad.gsmc
I have the following scenario
A cisco 6500 series switch with local vlan 10 and SVI 10 with ip 1.1.1.1 /24
A layer 3 etherchannel on the same switch with multiple sub interface.
One of the sub interface on the etherchannel is intented to be encapsulated with vlan 10. is it feasible to have such config on my box ?
if yes I have one more dream :-)
is it possible for me to use this new subinterface (which is encapsulated with vlan 10 ) and talk to a sytem which is part of vlan 10 on the other side of the ethechannel
the summary path will look like below
host in vlan 10 > SVI 10 on swith 1 > Etherchannel sub interface 10  on switch 1 > Etherchannel sub interface 10 on switch 2 > SVI 10 on switch 2 > destination Client in vlan 10>
will it remain a dream or any hope ?
please help
Giuseppe Larosa
Hello Prasad,
A dream or a nigthmare use L2 trunk etherchannels for this scenario
There are two types of problems:
address overlapping you cannot use ip addresses of the same ip subnet on different interfaces of the same device.
Each device should have only one L3 object connected to the a single broadcast domain
Hope to help
Giuseppe
taylormf1
I would pick either Switch 1 or Switch 2 to host the VLAN 10 SVI. Then use dot1Q Etherchannel trunks (L2 only) between the switches. I think this would greatly simplify your design. There is no reason for both switches to have a LVAN 10 SVI.
Mike
