Layer 3 port channel from 6500 VSS switch to two 6500 standalone switch
djai_ganesh
Configured Layer 3 portchannel from 6500VSS enabled switch to two different 6500 standalone switch. Configured first ip on VSS switch, second ip on standalone switch1 and third IP on standalone switch2. My question is
1. Will the portchannel be up?
2. If port channel is up, will I able to ping the connected IP's.
Raja.
Giuseppe Larosa
Hello D, Jaiganesh,
this setup cannot work an etherchannel can be configured between two systems, each system can be composite a VSS or a stack, but you cannot interconnect three indipendent systems with an etherchannel.
Use  indipendent L3 links and two IP subnets.
Hope to help
Giuseppe
