Enable traffic between 2 internal interfaces (cisco ASA 5510)
i have a cisco ASA 5510 and need to be able to have 2 subnet communicate with each other.
Ethernet 0/0 is the outside connection
Ethernet 0/1 in the main inside connection 192.168.32.x
Ethernet 0/2 is the 2nd inside connection 192.168.33.x
Both int 1 and 2 can connect to the internet but they cannot communicate with each other.
Please help?!?!
Christian
The running config is listed below:
: Saved
ASA Version 8.2(5)
hostname ciscoasa
enable password H4jV5cejsN/7lxxb encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.15.0 Warehouse description Warehouse
interface Ethernet0/0
nameif outside
security-level 0
ip address 195.171.223.67 255.255.240.0
interface Ethernet0/1
nameif inside
security-level 100
ip address 192.168.32.233 255.255.255.0
interface Ethernet0/2
nameif inside2
security-level 100
ip address 192.168.33.1 255.255.255.0
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
nameif management
security-level 100
management-only
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 8.8.8.8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list outside_cryptomap extended permit ip 192.168.32.0 255.255.255.0 Warehouse 255.255.255.0
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu inside2 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
nat (inside2) 1 0.0.0.0 0.0.0.0
static (inside,inside2) 192.168.33.0 192.168.32.0 netmask 255.255.255.0
route outside 0.0.0.0 0.0.0.0 195.171.223.65 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.32.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer 81.137.231.247
crypto map outside_map0 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 set phase1-mode aggressive
crypto map outside_map0 interface outside
crypto isakmp enable outside
crypto isakmp enable inside
crypto isakmp policy 10
authentication crack
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
authentication rsa-sig
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
authentication pre-share
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 50
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption aes-192
hash sha
group 2
lifetime 86400
crypto isakmp policy 70
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 80
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 90
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 100
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 110
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 130
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 140
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 150
encryption des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
management-access inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
vpn-tunnel-protocol IPSec
tunnel-group 81.137.231.247 type ipsec-l2l
tunnel-group 81.137.231.247 general-attributes
default-group-policy GroupPolicy1
tunnel-group 81.137.231.247 ipsec-attributes
pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:fa8de377ab001d57f8cba8d9b76789c1
: end
asdm location Warehouse 255.255.255.0 inside
2 Accepted Solutions
Ali Bahnam
Dear Chris,
Please try to add these steps to you ASA :-
- change the security level of inside2 interface to 50 instead of 100.
- Add these ACL
access-list internal extended permit ip any any
access-list internal extended permit icmp any any
access-list external extended permit icmp any any
access-list external extended permit ip any any
access-list internal1 extended permit ip any any
access-list internal1 extended permit icmp any any
access-group external in interface inside
access-group internal1 in interface DMZ
access-group internal in interface outside
Also change the static NAT to (static (inside,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.0.0)
Let me know if this work,
Hi Christian,
You have named that DMZ interface as inside1. So please apply like the below and check.
access-group internal1 in interface inside1 and check. It should work.
Please do rate if the given information helps you.
By
Karthik
Ali Bahnam
Dear Chris,
- Add these ACL
Thankyou very much.
The pings are now working one way (from inside to inside 2) but not the other way
DMZ interface wasnt recognised on the line:
cheers
Christian
Hi Christian,
By
Karthik
I fiddled about with what you sent me
I adjusted the line to:
static (inside,inside2) 192.168.0.0 192.168.0.0 netmask 255.255.0.0)
From
So yes that helped alot thanks
