Layer 3 routing
ssweehinlew
Level 3
Level 3
Can show me the simple example of Layer 3 routing? For example, route host A connect to host B via the switch 3650. What kind of configuration need to  be put on the switch?
7 Replies 7
tironevi
I do not think I understand your question. Are you trying to route between two hosts
that are physically conncted on the same switch but on different subnets?
Bingo. You are correct.
altheb_5
Level 4
Level 4
The L3 switch is L2 by default
if you need the switch come L3 you must enable routing by using this command
switch(config)#ip routing
Now the switch work L2 & L3
Ganesh Hariharan
Cisco 3560 series are L3 switches in order to make communication between vlan just confiogure ip routing in global mode with creating SVI for two vlan and rest will take care by 3560 switch for communication.
But not by default ports in 3560 are in l2 mode in order to make the port in L3 you need configure no switch port under interface level.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Folks:
Hes asked for a sample config.
Enter these commands at privileged exec mode on a L3 capable switch that has both hosts directly connected to the switch.
switch#conf t
switch(config)#
!enter these command lines!
ip routing (may be on by default)
vlan 2
name tax_division
vlan 3
name accounting_division
interface vlan 2
description default gateway for TAX Subnet
ip address 10.10.2.2 255.255.255.0
no shut
interface vlan 3
description default gateway for ACCOUNTING Subnet
ip address 10.10.3.2 255.255.255.0
no shut
interface gigabitethernet 1/0/1
description connection to  server on TAX Subnet
switchport mode access
switchport access vlan 2
no shut
interface gigabitethernet 1/0/2
description connection to server on ACCOUNTING Subnet
switchport access vlan 3
no shut
You wont need a routing protocol because the hosts are directly connected and the switch is enabled for ip routing.
Victor
Thank for your response. If I want to restrict certain ports in between these 2 networks. How it can be done on the access list?
Following on from Victor's post you would use acls ie.
access-list 101 deny tcp host 10.10.2.5 host 10.10.3.10 eq www
access-list 101 deny tcp 10.10.2.0 0.0.0.255 10.10.3.0 0.0.0.255 eq ftp
access-list 101 permit ip 10.10.2.0 0.0.0.255 10.10.3.0 0.0.0.255
int vlan 2
ip access-list 101 in
the above config would -
1)  stop host 10.10.2.5 connecting to the web server on 10.10.3.10
2) stop all ftp intitated traffic from 10.10.2.x to 10.10.3.x
3) allow everything else
Jon
