Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Yes, basic layer-3 is supported with this image. You can run static, RIP and EIGRP Stub with this image. If you want to run OSPF, ISIS, BGP, etc.. then you need IP services
Reza
Learn, share, save
