Layer 3 switch 3650 TS-S for running CCNP Version 7.0 R & S
Could anyone tell me that will the layer 3 switch 3650 TS-S with IP Base image sufficient for running CCNP Version 7.0 R & S.
In relation to the switching functions for CCNP Switch module will it support:
  • VTP v3
  • IP dhcp snooping
  • MST
  • rootguard
etc.
Further will it suffice for teaching CCNP Tshoot as well?
Also if one tries to upgrade it to Basic IP Services IOS  will it be possible?
Is it mandatory to buy the Layer 3 Switch 3650 TS-E for teaching CCNP Version 7.0 R & S? or one could use the layer 3 switch 3650 TS-S  instead?
istvan.kelemen1
You can upgrade L2 switch to L3, just get the correct software. Yes, for new CCNP R&S, I would say you shall really have L3 switches.
