copy running-config startup-config not saving
ajeni0001
hi,
 we bought a  cisco 3945 router recently. i did the initial configuration and saving is using copy running-config startup-config. but it is not getting saved properly. whenever i restart the router, it asks for initial configuration. that is every time i have to give IP address and other configuration after i switch off and on the router.
kindly help me
thanks and regards
Jeni A
There is a configuration-register that controls if the startup-config is loaded on startup or not. It's likely that the config is saved but not loadad. If this is the case, you can see your config with "show startup-config".
You can see the actual value of the config-register with "show version". You set the default-value with
config-register 0x2102
More on this topic is found in the config-guides:
http://www.cisco.com/c/en/us/td/docs/routers/access/1900/software/configuration/guide/Software_Configuration/appendixDconfigreg.html
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fundamentals/command/Cisco_IOS_Configuration_Fundamentals_Command_Reference/C_commands.html#wp5236362650
I also have this problem except mine is on a 3650. How do I go about changing this?
Hello
sh version
sh boot
sh flash:
res
Paul
Kind Regards
Paul
