Layer 3 Switch Inter-Vlan not working properly
keyursorathia
Hello All,
I have issue in configuring Layer 3 Switch Inter-Vlan routing.
The client in a particular vlan can ping the default gateway of the vlan but the clients in different vlans cannot ping each other. Also, PC in one VLAN cannot ping the default gateway of the other vlan.
Below is the configuration that I did on the switch,
Core Switch:
vlan 10
int vlan 10
ip add 192.168.10.60 255.255.255.0
vlan 20
int vlan 20
ip add 192.168.20.60 255.255.255.0
vlan 30
int vlan 30
ip add 192.168.30.60 255.255.255.0
int g1/0/19
switchport mode trunk
switchport trunk native vlan 50
ip routing
Layer 2 Switch:
vlan 10
int vlan 10
vlan 20
int vlan 20
vlan 30
int vlan 30
int g1/0/19
The below are the Layer 3 Switches and Layer 2 Switches in our company:
Layer 3 Switch - c9200l-24t-4g
Layer 2 Switch - c1000-24t-4g
7 Replies 7
--> switchport trunk native vlan 50
Where is Vlan 50 configured ? Post the full running configs (sh run) of both the layer 2 and the layer 3 switch...
Hello
FYI - you shouldnt require the native vlan to be created for it to be applied as native on a trunk interconnect, the trunk should work without it.
Can you post the following please:
On the core
sh arp
sh interface trunk
sh vlan brief
access-switch
sh interface trunk
sh vlan brief
Kind Regards
Paul
CORE Switch
SW_Core(config)#do show vlan bri
VLAN Name Status Ports
1 default active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/4, Gi1/0/5, Gi1/0/6
Gi1/0/7, Gi1/0/8, Gi1/0/9
Gi1/0/10, Gi1/0/11, Gi1/0/12
Gi1/0/13, Gi1/0/14, Gi1/0/15
Gi1/0/16, Gi1/0/17, Gi1/0/18
Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/23, Gi1/0/24
Gi1/1/1, Gi1/1/2, Gi1/1/3
Gi1/1/4
10 VLAN0010 active
20 VLAN0020 active
30 VLAN0030 active
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
SW_Core#show arp
Protocol Address Age (min) Hardware Addr Type Interface
Internet 192.168.10.60 - 28af.fddd.0b46 ARPA Vlan10
Internet 192.168.20.60 - 28af.fddd.0b56 ARPA Vlan20
Internet 192.168.30.60 - 28af.fddd.0b65 ARPA Vlan30
SW_Core#show int trunk
Port Mode Encapsulation Status Native vlan
Gi1/0/23 on 802.1q trunking 50
Port Vlans allowed on trunk
Gi1/0/23 1-4094
Port Vlans allowed and active in management domain
Gi1/0/23 1,10,20,30
Port Vlans in spanning tree forwarding state and not pruned
Gi1/0/23 1,10,20,30
CLIENT Switch
SW_Cli(config)#do show vlan bri
1 default active Gi1/0/19, Gi1/0/20, Gi1/0/21
Gi1/0/22, Gi1/0/24, Gi1/0/25
Gi1/0/26, Gi1/0/27, Gi1/0/28
10 VLAN0010 active
20 VLAN0020 active Gi1/0/1, Gi1/0/2, Gi1/0/3
Gi1/0/10
30 VLAN0030 active Gi1/0/11, Gi1/0/12, Gi1/0/13
Gi1/0/14, Gi1/0/15, Gi1/0/16
Gi1/0/17, Gi1/0/18
200 VLAN0200 active
204 VLAN0204 active
210 VLAN0210 active
SW_Cli#show int trunk
Gi1/0/23 1-4094
Gi1/0/23 1,10,20,30,200,204,210
Hello
Thank for sharing that information,
Can you confirm if:
Ip routing is disabled on the access switch.
Any software firewall enabled on the hosts negating ICMP?
Kind Regards
Paul
Martin L
Most often problems with this situation are:
trunks are not formed;
missing vlans on layer 2 switch; even if traffic is passing thru (via trunks), that switch still needs vlan and trunks;
Layer 2 switch can only have 1 interface vlan up up state since it does not do routing. So, PCs' default gateways should point IP to layer 3 switch or router.
Double check all access ports and their vlans ids .
Regards, ML
**Please Rate All Helpful Responses **
I have checked many times the vlan configuration and it is configured correctly.
Zanthra
Could you share the IP configuration for one of the clients? Particularly IP Address, subnet mask, default gateway, and static routes if any.
