Layer 3 Vlan with Pix router, NAT issues, Please help
sean chang
Our enviroment: backbone switch Catalsyt 3560X with Layer 3 inter-Vlan routing
Router: Pix 515E , software version 8.0.4
we have L3 vlans using VTP on the switches, inter-vlan working, 2 Vlans are as the following:
vlan 1  : 10.1.1.1/255.255.0.0
vlan192: 192.168.1.1/255.255.255.0
the switch default gateway:10.1.1.254, which is the INSIDE interface IP of Pix515E, ALL Nat on vlan 1 is working fine.
Question: how do I configure NAT for vlan 192?
so far I have tried the following without results:
1. Configure a  Vlan 192 on INSIDE interface on PIX with IP=192.168.1.2/24-------Not working
2.Configre a Vlan on INSIDE interface on PIX without IP address------NOT working
3. Don't configure any Interface on PIX for vlan 192----not working
In all cases, PIX says something like "No translation group found for tcp src inside:192.168.1.3/3000 dst=www.oracle.com"  ...
I have googled for a while and run out of my wits now. Any suggestions and advices are  greatly appreicated
Jon Marshall
If you are routing on the L3 switch then you don't configure a vlan 192 interface on the pix.
When you say the default-gateway for the switch is the pix inside interface do you mean on the 3560 you have -
ip route 0.0.0.0 0.0.0.0  10.1.1.254
If so then you just need to setup NAT on the pix and add a route to the pix for the vlan 192 subnet.
The nat depends on what you already have ie. if you have
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
then that should cover the vlan 192 subnet as well. If you have -
nat (inside) 1 10.1.1.0 255.255.255.0
then just add -
nat (inside) 1 192.168.1.0 255.255.255.0
you also need a route on the pix as mentioned ie.
route inside 192.168.1.0 255.255.255.0
If the routing is being done off the pix for these vlans then please come back with more details.
Edit - took out last bit about different setup so as not to confuse current issue.
Jon
dominic.caron
Level 5
Level 5
Please provide the nat config of your firewall
Line beginning with : static, global or nat
Jon Marshall
then just add -
Jon
Thank you Jon, you nailed it. Your solution saves me  lots of time and  trouble.
My shortened  NAT looks like this way: ( in Catalyst switch 3560X, I did have:
ip route 0.0.0.0 0.0.0.0  10.1.1.254 )
global (outside) 10 interface
global (dmz2) 10 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 10 10.1.0.0 255.255.0.0
nat (inside) 10 192.168.1.0 255.255.255.0<------newly added according to Jon's advice
but the most critical part of which I never thought about  is this line:
route inside 192.168.1.0 255.255.255.0 10.1.1.1  ( I have been trying: route inside 192.168.1.0 255.255.255.0 10.1.1.254 before without success, I did not know this Vlan 192 should use L3 Vlan IP  of the default network)
Again, I really appreciate your great advices.
