05-03-2011 04:09 AM - edited 03-06-2019 04:53 PM
I need to replace line card in 4006 Switch, Please give ur suggestion.
NOTE: it is a production environment.
05-03-2011 04:51 AM
If you are on a tight budget and have no PoE requirement, the WS-X4548-GB-RJ45 will suffice (note that per 8 port group [6 total] there is a 1Gbps bandwitdth share). On the higher end, (still no PoE requirement) look for the WS-X4648-RJ45-E which is essentially the same with a few added features and 3Gbps bandwidth per 8-port group. If you need PoE, go for the WS-X4748-RJ45V+E which also comes with 3Gbps per 8-port group.
For more details:
Please rate helpful posts.
05-03-2011 03:40 PM
Please give us more information? What supervisor engine do you got? What are you trying to replace? The supervisor card or the line blades? Can you explain by your term of "replace"?Find answers to your questions by entering keywords or phrases in the Search bar above. New here? Use these resources to familiarize yourself with the community:
