What color is LED?
Keiko Imachi
The network-topology looks the following chart.
When port is blocking ports at PVST mode, LED is orange blinking.
what color of LED is at Rapid-pvst mode?
Please look at the attached files.
Catalyst2960S Gi1/0/20(Blocking port)
Catalyst3750E( Act) =====Catalyst3750E(Stand)
-----------------------------(GEC)  -------------------------------------
         | Gi1/0/20                           |Gi1/0/20
         | Gi1/0/1                             | i1/0/20
                         Catalyst2960S
             |(Vlan20)                         |(Vlan30)
                  PC                                 PC
12 Replies 12
andtoth
Level 4
Level 4
It is the same regardless of STP mode. However, note that it won't be orange if it's a trunk link because it might be forwarding (not blocking) for other vlans.
Best regards,
Andras
Thank you for replying.
It set it as follows.
Trunk pot:
Interface gi1/0/20
Switchport trunk mode
Switchport allowed vlan 10,20,30
Spanning-tree cost 200
Led of blocking port is green.
Best Regards,
The LED in this case is green because it is status/protocol up/up.  The STP status is not associated with the green light, as the green light is relation to physical layer functionality (ie. the port is up with matching speed/duplex and is now passing traffic).
In this case,led of bolcking port is green,and is it correct?
I worry that I was not wrong in the setting
Best Regards,
Keiko Imachi
Correct. You can check by looking at the switch CLI via telnet or SSH and use the 'show spanning-tree ' command to verify the port state for each vlan.
Andras
This is correct.  If a port is up and blocking in a particular vlan, the LED will still show green to indicate an active connection.  No worries, this is running correctly as it should.
I'm sorry for reply so late.
I could understand.
Thank you for a comprehensible explanation.
Best Regards,
Keiko
As I mentioned, the LED will only reflect the STP blocking status with an orange light if it's not a trunk port. In your case, since it's a trunk port, the LED will stay green.
Thank you for many explanation.
I am glad for your help.
Best Regards,
Keiko
Please don't forget to mark the post as answered and rate the posts as well.
Andras
Hi Andras,
I forgot to post the mark.
Thank you so much.
Arigato
Keiko
