linevty and mgmt interface
Arjun Dabol
I have a 6800 switch and it has mgmt 0 interface.
I want to disable line vty completely (telnet and ssh both) and just want to allow access via this int. mgmt 0.
can someone tell what config needs to be done for this on 6800 ?
thanks
Leo Laohoo
You still need VTY but put an ACL to only allow access via the Management port subnet.
and to add to Leos point souce all the traffic from the mgmt going outbound too for mgmt protocls that you have in use
ip tacacs source-interface
logging source-interface
ntp source
ip tftp source-interface
ip ssh source-interface
snmp-server source-interface informs
Thankyou .
Ok so in my case I have a router with mgmt interface (int mgmt 0) with ip address 192.168.1.1
Now I want that my network administrator sholuld telnet in to the router using only this int mgmt IP and Not any other loopback OR interface IP configured on the router ? So where exactly i configure this ACL and apply ?
